Old 03-04-2008, 12:42 AM
InneedofHummer InneedofHummer is offline
InneedofHummer is on a distinguished road
Default H2 lift kits? Any bolt on?
I know that most people say to buy a Fabtech lift, but is there a lift out there that is a bolt on. I don't want to have to pay someone to install the lift. That would likely cost $800 or more. I am trying to find something I can install. I have done several Jeep lifts, but have never done any welding or cutting. It seems as though most H2 lifts require some welding, which I think should be done professionaly. Thanks
Old 03-04-2008, 01:01 AM
ib3's Avatar
ib3 ib3 is offline
ib3 is on a distinguished road
Default Re: H2 lift kits? Any bolt on?
Bullet proof = No Welding - Minor cutting with sawzall. But seriously not a do it your self job for every day person.
Check out levelers and shock extenders. Thats a good so it yourself, About an hour with hand tools. Just dont forget to do a alignment if you alter ride height..
2008 Solar Flare H2 - BulletProof 6" Suspension - Diamo DI17 20" x 10" - 38x15.50x20 Nitto Mud Grappler - HID 8000k -
Old 03-04-2008, 01:24 AM
I can't seem to find a instruction guide on Bulletproof. I think I want at least 4" of lift. I don't think I can get that w/ out a suspension lift. The Bulletproof sounds like something my buddies and I could do. Are there any other H2 lifts that are easy installs?
Old 03-04-2008, 01:55 AM
ib3's Avatar
ib3 ib3 is offline
I can send you a copy of the bullet proof install guide tommorow when I get to work if you want. Its pretty close to the same as all the other lifts except you use the stock spindle so the upper control arm drops also. The results are the front differential does not have to be cut. The only welding you have to do is if you decide to put it back to stock..
Old 03-04-2008, 02:32 AM
Sounds great...thank you.
Old 03-04-2008, 03:08 AM
ib3's Avatar
ib3 ib3 is offline
Are you still in need?? Or did you end up buying??
Old 03-05-2008, 02:17 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Can you send me that too? Thanks
Old 03-05-2008, 05:49 PM
ib3's Avatar
ib3 ib3 is offline
Im having some problems with my scanner but I will get it working. there are a few steps left out, I have contacted BulletProof about them and they are going through and correcting them now.
Old 03-04-2008, 05:30 PM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
Take your time alot of information but the only way to go is up.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
