Old 03-09-2008, 03:16 AM
Cyanide Cyanide is offline
Cyanide is on a distinguished road
Cool Power door locks
my electric door locks went out, I replaced the module and only the passenger side of the vehicle is working. my keyless pad doesn't unlock or lock. can someone please tell me how to reset so that my remote button will work; and get the driver's side locks work too
thanks,
ric
Old 03-09-2008, 05:12 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Default Re: Power door locks
thanks,
ric
By "keyless pad" I assume you mean your wireless remote key fob? Here's the info I think your looking for... hope this helps!
PROGRAMMING INSTRUCTIONS FOR GM TRUCKS AND SUV?S
2002 2003 2004 2005 2006 (2007 classic) models
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver?s door panel-continue to hold down until instructed to release.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
11. Repeat the previous step for each additional transmitter (including any existing transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
