Old 04-04-2008, 06:00 AM
jdrew's Avatar
jdrew jdrew is offline
jdrew is on a distinguished road
Default Water Leak H2 SUT
I bought an '05 SUT last weekend with 40k on the clock. Well, the gremlins are starting to come out now.. I noticed a small couple of drips on the inside of the windshield when it rained the other day.. I replaced the windshield hoping to have this problem fixed. (Dealership paid for the replacement).
Well, today, it rained a lot more and when I came to a stop after the truck sat for 8 hours, about 1 oz of water came out of the headliner and driver side visor clip. I thought maybe one of the marker lights could be the culprit, so I checked them for fit. All fit fairly tight, except the one in the middle that is directly above the steering wheel. It was a little loose.. i took it out, of course breaking one of the retention clips and used some silicone to realseal it back up until i order a new one in the morning. (I'm hoping that this may stop the leak with the silicone..?)
I checked the sunroofgasket, as well as the sunroof drip lines that run in the headliner and they are attached. I am unable to see any wet spots on above the headliner on the sheet metal..
Anyone have any ideas or know of a likely culprit?
Evansville, IN
'05 H2 SUT Slate Blue LUX w/Nav, NightDriver
H.O.P.E. Member
Old 04-04-2008, 06:25 AM
jdrew's Avatar
Default Re: Water Leak H2 SUT
nevermind.. I must have misspelled during my search.. i found the answers i was looking for..
Evansville, IN
H.O.P.E. Member
Old 04-04-2008, 12:19 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Ok what was the answer, did you have after market light bar and the marker light groumet is leaking?
Old 04-04-2008, 03:40 PM
jdrew's Avatar
marker lights, no light bar
Evansville, IN
H.O.P.E. Member
Old 04-05-2008, 07:54 PM
H2Finally's Avatar
When this happen to mine, the culprit was clogged sunroof drip lines. Never had a problem with my marker lights.
Can BLING Get You Home?
Old 04-05-2008, 08:05 PM
codeman671 codeman671 is offline
codeman671 is off the scale
My 03 had serious leaks from the roof marker lights.
