04-06-2008, 03:27 PM
08 SUV SpareTire Relocation Options
The spare tire is to close to my trailer jack and comes in conntact with it when making turns. The roof is not an option (garage door hight). No more hard points in cargo area for bolting in tire bracket. Other than laying flat in cargo area or omitting spare all together does anyone have any ideas.
04-06-2008, 06:43 PM
Re: 08 SUV SpareTire Relocation Options
Omit the tire all together, have that nice clean look. Like this
04-07-2008, 04:43 AM
04-07-2008, 05:09 AM
On my Yukon and Bronco before that I had made a bracket and it hung in the Garage all the time I owned vehicles and my Avalanche as well. I just bought one of those big cans of fix the leak and air fill. Never used it. I'm getting ready to do something with this spare too because it's a real pain in the butt to have to swing it away every time before lifting tailgate. Plus the trailer factor and extending hitch which is not best thing for trailering. So hang it in garage and Good Luck.
H2 REBEL lennyrebel
04-08-2008, 04:02 AM
I'll put it in the garage. I never had a flat on any of my H2s. Back in 2003 when storage of the spare tire in the cargo area was the norm I thought the rear of the truck looked much better. I won't miss the extra weight either. But of course it can't be that easy. Vehical tag lighting wire now comes out of the bumper cover through a grommet. A plate bracket bolted to the recovery loop mounting could be an easy out but I find the vibration of these makes for a short bulb life. I'll look at routing wires to the original mounting area on the rear door. I,m off to get a can of green goo.
04-09-2008, 12:02 AM
a word of warning before taking it off: i took it off my 08' then noticed that the back of the truck rose up about 2" and the front nosed down. The ride was noticably worse. and the handeling was wierd. The tire and rack weighs close to 290 pounds. I weighed it. The suspension is set up to accomodate that weight and overhang on the back of the truck. I was going to crank up the t bars to raise the front, but just decided not to mess with it and leave it alone. I put it back on within a day.
2008 H2
04-09-2008, 03:38 AM
what i did is to put some longer screws then put first some bolts that will serve as a spacer.
hope it helps.
have a nice day..
___________
Audi S4 Brakes rules
Audi S4 Clutch Kit knows what you need.
04-13-2008, 07:37 PM
I had the same problem and I bought a hitch extender. Made for HUMMER. I bought mine on e-bay for $40. Not for real heavy trailers though.
2008 Solar Flare H2 - BulletProof 6" Suspension - Diamo DI17 20" x 10" - 38x15.50x20 Nitto Mud Grappler - HID 8000k -
04-14-2008, 04:59 PM
I have the same issues with trailers! I dont have any issues with my boat or seadoo (2) trailer. With my 5x8 enclosed trailer, it rides too close, so I got an 18 inch extender. Dang thing is solid and weighs about 25-30 pounds.
You could maybe mount your spare on the trailer?? Not sure if that would work. Good luck. I thought about leaving mine int he garage too.
SJK
2008 H2 Greystone, Corsa Sport Exhaust
Luxury package, Air Ride, Nav, DVD, Sunroof
Sedona Leather (nice!!) Dark window tint
Euro/smoke tint side, top and rear marking lights
K&N cold air kit, GM lockpic
www.TeamShooters.com
04-14-2008, 10:38 PM
Spare tires rule, i have 2 on my rig.
----------o-o-o-o-
[[_]|[]|[][___  ]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
04-15-2008, 12:40 PM
Brad, Where are they mounted?
Al
Hybrid Mode
