Old 04-20-2008, 09:41 PM
Default tailight bulb???
Bottom tailight on the right side is out, it is a brake light the one on the bottom in the bumper of the truck, how do i get in there to replace it, im hoping this is what the problem is, its funny thou cuz when i hit the key fob to lock the truck it flashes but when u hit the brake pedal nothing, WTF?? first of all how do i get in there??
Old 04-20-2008, 10:52 PM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
Default Re: tailight bulb???
it is a dual filament bulb. that is why one circut works and other does not. To change them first lift the tail gate and you will see two torque screws on the insde door jam of each light housing. remove these screws and then you can see the door side of the light housing can gently be pulled forward about an inch or so. after you gently pull forward, you want to try and slide the light housing towards the inside (aka, towards the door or lift gate.) after you slide towards the inside you will feel the entire light housing come loose. Just pull forward and twist the bulb socket and pull out. replace bulb and reverse process. all the bulbs in the rear are 3157 bulbs. Hope this helps. If you need any more help or need some photos or something just let me know.
B
Old 04-21-2008, 01:05 AM
H2Finally's Avatar
Originally Posted by 8500lbs
... slide the light housing towards the inside (aka, towards the door or lift gate.)...
Crucial bit. The light housing clips onto the outer edge of the body panel.
Can BLING Get You Home?
Old 04-21-2008, 04:57 AM
u guys realize iam referring to the light in the plastic bumper right???
Old 04-21-2008, 05:40 AM
Rico001's Avatar
Rico001 Rico001 is offline
um um um
You did not tell us you had the
optional lights in the bumper.
Hell the last time you were on here you were selling
your older Hummer with the Carbon Dash and buying an
08.
So what do you have now?
~Richard
Old 04-22-2008, 04:28 AM
Originally Posted by Rico001
um um um
08.
~Richard
FIGURE IT OUT, It is an 05 SUT and rico u are a fukkin total retard and have no idea waht or who u are talkin about sooo GO FUKK URSELF, HOMO
Old 04-27-2008, 11:25 PM
um um um
08.
~Richard
Once again, ur clueless
Old 04-21-2008, 05:42 AM
8500lbs's Avatar
nope I have an 04 and there fore do not have them, so I cant help ya there. Then again I dont prefer them so I would tell ya to just yank both of them out but that is just me. Sorry I couldnt help.
Good luck,
B
Old 04-21-2008, 08:48 AM
If in bumper it is most likely an aftermarket setup.
Some came with brake and turn signal but, sum were just turn signal.
Depending on how the person wired it to harness below he could have had both, only turn or brake only.
TAZ
Old 04-20-2008, 11:24 PM
Rico001's Avatar
#1 open tail gate
#2 remove 2 screws
#3 pull tail light assembly out
#4 twist lamp holder counter clock wise
#5 remove bad bulb
#6 install new bulb, wipe off oil from fingers
#7 install bulb holders back into taillight
#8 put taillight back on truck
#9 reinstall screws
#10 check bulbs
#11 close tail gate
~Richard
