Old 04-23-2008, 03:09 PM
st kitts st kitts is offline
st kitts is on a distinguished road
Default broken exhaust bolts
I brought my H2 in to check for an exhaust leak. The dealer found broken exhaust manifold bolts on both sides. They want $1000 to fix. Is this common?
Old 04-23-2008, 04:01 PM
homeboy homeboy is offline
homeboy is on a distinguished road
Default Re: broken exhaust bolts
my dealer said that it was common on h2s,ihave an h3 with a warped head which led to a broken bolt on my exhaust manifold,mine also sounded like it had an exhaust leak.
Old 04-23-2008, 04:20 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
OrangeCrush had the same problem a couple of years ago. To bad the photos have been removed from <THIS THREAD>.
Old 04-23-2008, 08:28 PM
rpm07's Avatar
rpm07 rpm07 is offline
rpm07 is on a distinguished road
Alot of h2s have had broken bolts. My 03 had 2 of them alot of people I talked to told me they always break. So I went and picked up a set of Edelbrock shorty headers for $250 and put them on, so far no problems and it only took 3 hrs. I figured if I had to remove the stock manifolds to fix the bolts I was not going to put them back on.
Old 04-24-2008, 12:03 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
It is a fairly common failure. There are new bolts that are supposed to correct the problem. They are likely quoting you worst case scenario repair cost which would mean removing both cylinder heads to repair. Sometimes this is required but in most cases the broken bolts are easily removed with head removal so that is the question you would want to ask them.
