Old 05-08-2008, 11:03 AM
davyo davyo is offline
davyo is on a distinguished road
Default 18" wheel and tire size question
So me thinks I have decided on a 18" wheel for my H3 (I think this the correct size that will fit 18X10 6-139.7HC-25C), Im asking because Im a total dumbass when it comes to tire and wheel sizes and bolt patterns and I also dont know the correct offset,,, I dont mind if the wheel/tires comes out a bit from the fenders.
As far as tire size, what would be a good tire size to look for in a A/T tire with a big fat meaty wide look that wont rub with no lift or t-bar cranking.
Thanks in advance for any help and bearing with my lack of knowlege when it comes to tire/wheel sizes.
Cheers
Davyo
Old 05-08-2008, 12:19 PM
Default Re: 18" wheel and tire size question
There is alot of choice out there! You could start by visiting STS or a local dealer and checking some Toyo Open Country A/T or M/T if you do alot of off road. The M/T's are aggressive and will sing on the highway. Not help your MPG too much if you go with 35". They are great in the mud and sand however. The Toyo A/T is better for mostly on road performance.
After looking there try searching here under tires. Once you narrow your search shop pricing for your best deals...
Good luck.
Old 05-11-2008, 05:17 AM
I have one question that I have been finding hard to get an answer for,, what is the range of offset for an 18" wheel ??????
Cheers
David
