Old 06-02-2008, 01:59 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
Default Aircon - not working
Hi all
After I fianlly got my H2 back with a new engine installed the aircon have now stoped working.
It's not makign cold air ??
So My guess would be that it needs a refill af whatever it is that they put in it.
So i called one of the few shops in the Copenhagen area thats actually services aircon, and they will gladly help me put some new fluid/gass whatever onto the system. But they don't know how much fluid to put in. Do any of you guys know how many grams or units need to be put in.
Or do you think it's something complely different. Compressor or something
Regards
Rene
Old 06-03-2008, 03:07 PM
Default Re: Aircon - not working
start with 1.4 lbs R-134A refrigerant. it's marked on top of receiver-driver(large aluminum can at firewall)
Old 06-04-2008, 01:35 PM
Thanks will try to drive by the shop today. Will let you all know how it turns out
Rene
Old 06-05-2008, 12:08 AM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
This might sound silly but, did you check the belt that drives the compressor? Whoever put the new engine in might have forgot to put it on. The compressor is driven by a seperate belt from all of the other accessories on the truck.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
Old 06-05-2008, 04:07 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
May not be silly at all... Rene, you can easily check this yourself. The compressor is mounted at the bottom of the engine, if I recall correctly it's on the passenger side.
Old 06-07-2008, 05:51 PM
LEcustoms's Avatar
It is on the lower passengers side of the engine.
03 White H2
06 kawasaki stx-15f
02 yamaha superjet
Old 07-24-2008, 02:52 AM
splne1's Avatar
splne1 splne1 is offline
Dang did not know this!!! Thanks LE!!!!
Old 07-24-2008, 12:55 PM
Hi Guys
Planohummer - Thanks, This was excatly what the aircon guy needed.
I just had the aircon filled up about 3 days ago, and now everything is working.
I did chck the belt and that one was oki, and I also checked the magnetic thing on the flywheel that makes the compresser run.
But it was the cooleant (maybe wrong spelling)
Now just waiting to see if it's leaking anywhere
Regards and thanks
Rene
Old 07-23-2008, 11:42 PM
TedW TedW is offline
TedW is on a distinguished road
Good evening, or morning perhaps by the time you read this, H2 or H1, what year? I have an 08 H2 that I am having REAL A/C problems with, and would love to coordinate research. Service manager said "we have no problems with 08 H2 A/C's", the "tech" doing the work said (sorry this is a quote) "they suck". My truck is still in the shop after having the compressor replaced once already (only 13k miles/22km) I owned an 03 H2 prior. So if yr talking an 08 or perhaps 05+ H2, we shoul dcompare notes. Let me know what you think. Kind Regards, Ted
