Old 06-05-2008, 04:14 PM
CrackerJackToy CrackerJackToy is offline
CrackerJackToy is on a distinguished road
Default What does everything think about the gas/h20 mix for big fuel efficiency..?
I got to reading around & looking on youtube, and I noticed that using gas/h20 mix will yeild very high gas mileage increase. You must run two seperate tanks, one for gas, one for water, but should yield 20+mpg on the h2 in the city. It should also yield 28-30mpg in the city for my Corvette, if its as true as the customer testimonials.
I figured I would ask everyones opinion here, since $4 a gallon & only rising really hurts.
Old 06-05-2008, 06:02 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Default Re: What does everything think about the gas/h20 mix for big fuel efficiency..?
Snake oil.
Old 06-05-2008, 06:33 PM
HummerJim's Avatar
Water injection on piston and turbine engines is not new. It was used tested by Tom McHale in Mechanics Illustrated in the 50s on a '57 T -bird (yep, I'm an old fart, but I loved his car reviews). His verdict was it did nothing at all. The original Boeing 720, 707 and KC 135 used water injection as a means of increasing the density of the air flowing out of the burner cans, but it used a tremendous amount of water.
The most famous pitson engine with water injection was the Pratt and Whitney R4360 producing 3800 horsepower on the C124, Globemaster. The water injection system required ADI or ADF (anti detonation fluid), but the water injection system was disabled on all the engines in the '70s because of burnt pistons and valves due to uneven combustion caused by water injection. Anti detonation fluid was required because adding water to gas lowers its octane rating (dillutes it) while increasing the mixture's density. Water injection on the R4360 was used to increase horsepower when overgrossed, but had no effect on pounds of fuel burned..
Old 06-05-2008, 07:19 PM
MDimitri's Avatar
MDimitri MDimitri is offline
If there is no symptom of degradation to valves, pistons, rings and actual Hydrogen & Oxygen burn in the cylinder along with atomized fuel then this is a viable alternative. The below numbers are impressive: Albeit some of the numbers barely get by the 50% mark. A negligible improvement was on the GMC-2500, but still enough for the owner to realize a savings.
Old 06-05-2008, 11:05 PM
This is exactly what im talking about. Hydrogen based alternative fuel.
(Sorry for putting h20 which is water in the title, guys.) I am FULLY aware of what methanol/alcohol/water injection is, and how it works. I used to drive an evo, and that is the every day norm for evo drivers to do. Although, I am NOT talking about water injection here, rather, I meant hydrogen!
A local guy here on my local car forum has a home made kit he put together for his bike. He claims before he was getting 60mpg, and after the kit (which I could have swore he said gas and h20 mix), he claims hes getting 150mpg. I believe he is running straight hydrogen though, and not a hydrogen/gas mix.
I figure, why not implement this into the H2, and get 25mpg in the city.
Old 06-05-2008, 11:10 PM
Here is a quote from him, from earlier.
I build a hydrogen generator that basically has 2 stainless plates that conduct 20 amps through a very small cell that then produces what is called brown's gas. It splits the Oxygen and hydrogen atoms and converts them to a gas. So you get hyrdrogen (which is the fuel) WITH OXYGEN which makes more power.
It got 60mpg before the cell.
Old 06-06-2008, 01:11 AM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
This such a crock of psuedo-science and junk documentation. Hydrogen by itself has virtually no power output when burned. It is also a ganged element, meaning that in natural form, 2 atoms are bonded, i.e. H2. (Clever huh, H2 forum...oh nevermind). In a typical hydrocarbon, there can be up to 26 Hydrogen atoms PER molecule! The claims that a vehicle mounted electralysis device will convert milliliters of water into enough hydrogen to propel a full size vehicle hundreds of kilometers is ludicrious.
HHO gas, or Brown's gas, can and does burn hot. That's it, but as an alternative fuel source? No way. There isn't enough BTU per gram. Also, it is extremely dangerous to store, a single blowback can destroy the generator system very fast, think Hindenberg.
The best way to utilize Hydrogen is the fuel cell, stripping the single electron, utilize the negative charge for "work", then returning it to its proton unchanged where it is combined with oxygen to make water. I'm all for that, bring on the diesel/fuel cell electric Hummer! We would be able to sneak right up and drive over the leaf lickers as they sniff their self-righteous asses and lick psychodelic toad skin.
Old 06-06-2008, 03:44 AM
Ok, so then how about gasoline + hydrogen injection if hydrogen has no power output?.. Hydrogen is very flammable. There is a HUGE amount of people who have test hydrogen injection over the net who have great & positive results. I have yet to come across someone who has tried it & had no results whatsoever. But then again... you & I have never tried, so we cant really give any real input here.
Old 06-05-2008, 07:22 PM
Methanol Inject is a biggie on blown engines where detonation may be a problem, but on a N/A otto cycle auto motor it is nothing but a way to sell water injection kits to folks who believe market hype and in theinlg like the Tornator...or whatever that cut up Coke can thing is they stick in the CAI.
Want-08 Viper, 06 M5
Old 06-06-2008, 11:50 PM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
Just got back from RAMP Hummer today, got a new battery and clearance light under warantee.
While talking to the service Manager, he told me about a guy they deal with that has put on one of these hydrogen/gas units and it averaging around 27MPG. He said this was confirmed by others that have drive the H2 and by the avg fuel econ display.
Would the display show such an increase? How does the display get a readout? I was thinking from a VAC sensor? Does it actually look at the injector pulses and figure it out from that?
I have to plug the dealer real quick, as their serivce is simply awesome. I didnt even buy the truck from them, but still they are always ready to help. I just show up and they do the work right there, on the spot, and seem to have almost everything in stock. Never have I had an issue, had to argue a point, or to prove anything to them. Even If i have to pay a bit more, I will buy my next truck from them. This is really what helps the brand, dealers like this.
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 06-07-2008, 08:45 AM
If hydrogren say were to work. Has anyone thought of the next issue.
Liquid hydrogen is a hazordous material that does require a hazmat endoursement on a CDL license. Perhaps in smaller amounts it is OK?
Just thought I would mention as I'm curious at least on this part.
TAZ
Old 06-14-2008, 02:15 AM
--John
Impressive results. Probably highway results though.
Old 06-14-2008, 08:51 AM
johndjmix1's Avatar
27mpg highway is fine in my book!
--John
Mods:
Warn 9.5 Winch
Old 06-16-2008, 07:37 AM
kalantar kalantar is offline
kalantar is off the scale
I would be very happy with 27 mpg.
Old 06-16-2008, 03:27 PM
BlueTJCO's Avatar
BlueTJCO BlueTJCO is offline
Prob bull **** results. If this was practical and easy on a new vehicle it would be everywhere, and it wouldn't have taken higher gas prices and a forum to dig it up.....
"moonie"
Old 06-16-2008, 07:12 PM
TRUBRIT's Avatar
TRUBRIT TRUBRIT is offline
TRUBRIT is on a distinguished road
Well.....it is out there.
http://www.water-for-fuel-scam.com/index7bfuel.htm
They have tried these in the Big Rigs too. Not so successful with the Diesel Engine.
On the news the other day they had a test car running around Tokyo running with just a Hydrogen Generator. Only water as the fuel.
Everyone was sceptical about running a Diesel on old cooking oil....now look. XTreme 4x4 was showing in detail how to make your own Bio Fuel. Works out to $1.20. Kit costa $8,000.00.
Don't blow off the Hydrogen idea too quick.
Old 06-21-2008, 05:24 PM
johndjmix1's Avatar
So no one here is going to spend the $65 to $300 to try this out?????
Ive tried out enough stuff (Bud Light, Corona, Miller), your guys turn.
--John
Mods:
Warn 9.5 Winch
Old 06-16-2008, 03:25 PM
BlueTJCO's Avatar
--John
You should see what gas mileage I can get my display to read at sometimes......
"moonie"
Old 06-22-2008, 06:58 AM
I'm also currious why you feel the need to troll with such a weak lure?
BTW, you should stay on vehicle sites that are appropriately related to yours.
http://youtube.com/user/abercrombie3607
