Old 07-21-2008, 06:31 PM
jersey jersey is offline
jersey is on a distinguished road
Default H3 Onstar loose ground sound
Onstar works sometimes and at other times I get a loose ground sound. Onstar diagnosed came up with nothing. I tightened the battery cables which were very loose, and that seemed to work until I drove home and retested it a few hours later and the noise returned. I live on the Jersey shore, far as I know we get a good signal there. My neighbor has Onstar and has no problems with such a sound. Only the Onstar is affected. Everything else works great. Anyone have any ideas what I can check to fix such a problem?
Old 07-29-2008, 12:11 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: H3 Onstar loose ground sound
Subject:Audio Whine Noise from Radio Speakers When Using OnStar? (Install Noise Suppression Filter)
Models:2007-2008 GM Passenger Cars and Trucks (Including Saturn)
2007-2008 HUMMER H2, H3
2007-2008 Saab 9-7X
with OnStar (RPO UE1)
This bulletin is being revised to update the circuit descriptions in the correction statement. Please discard Corporate Bulletin Number 07-08-46-002A (Section 08 -- Body & Accessories).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2139137&from=sm#ss1-2139137">Condition
Some customers may comment on an audio whine coming from the radio speakers when using the OnStar? system. The amplitude and frequency of the whine will change with an increase or decrease in engine speed.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2139137&from=sm#ss2-2139137">Cause
This condition may be caused by electrical noise on the OnStar? Vehicle Communication Interface Module (VCIM) battery feed wire being passed to the microphone output pins at the radio.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2139137&from=sm#ss3-2139137">Correction
Technicians are to install a noise suppression filter, P/N 1224205, into the OnStar? battery voltage circuit, a few centimeters (inches) from the VCIM. The filter package has three attached wires - a single yellow wire at one end with a yellow wire and a black wire at the other. Install the single yellow wire side into the battery voltage circuit towards the VCIM. Install the remaining single yellow wire into the battery voltage circuit toward the fuse and the black wire to ground.
Important: The noise suppression filter is polarity sensitive. The filter is designed to be most effective when the end with the capacitor ground is connected towards the source of the electrical noise. Install the filter in this polarity first. If the noise level is still not satisfactory, try disconnecting the capacitor ground. In some cases, if the first installation does not correct the noise, try reversing the filter polarity (removing the filter, turning it end for end and then reinstalling it) and grounding the capacitor lead.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2139137&from=sm#ss4-2139137">Parts Information
Part Number
Description
Qty
1224205
Filter, Universal Alternator Whine
1
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2139137&from=sm#ss5-2139137">Warranty Information (excluding Saab U.S. Models)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N6632
Wiring and/or Connector - Vehicle Entertainment -- Repair or Replace
Use Published Labor Operation Time
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2139137&from=sm#ss6-2139137">Warranty Information (Saab U.S. Models)
Old 07-29-2008, 02:43 AM
Hey HT,
Thanks for the info! Do you think it matters that my H3 is an '06? It sounds like that is exactly the problem.
Hmmm....wonder if they have on of these that'll fit my wife?
Old 12-17-2008, 02:58 AM
drewtiss@hotmail drewtiss@hotmail is offline
drewtiss@hotmail is on a distinguished road
Originally Posted by HUMTECH
Subject:Audio Whine Noise from Radio Speakers When Using OnStar® (Install Noise Suppression Filter)
Models:2007-2008 GM Passenger Cars and Trucks (Including Saturn Parts)
2007-2008 Saab 9-7X
Some customers may comment on an audio whine coming from the radio speakers when using the OnStar® system. The amplitude and frequency of the whine will change with an increase or decrease in engine speed.
This condition may be caused by electrical noise on the OnStar® Vehicle Communication Interface Module (VCIM) battery feed wire being passed to the microphone output pins at the radio.
Technicians are to install a noise suppression filter, P/N 1224205, into the OnStar® battery voltage circuit, a few centimeters (inches) from the VCIM. The filter package has three attached wires - a single yellow wire at one end with a yellow wire and a black wire at the other. Install the single yellow wire side into the battery voltage circuit towards the VCIM. Install the remaining single yellow wire into the battery voltage circuit toward the fuse and the black wire to ground.
Part Number
Description
Qty
1224205
1
Labor Operation
Description
Labor Time
N6632
I am a DYI guy, but I am having a problem installing the blue wire to chassis ground and still needs to fix the red wire to the amplifier.
Old 12-17-2008, 01:46 PM
If you are using a non stock radio/stereo system a condition of noise is common.
