Old 08-10-2008, 12:06 AM
rw789 rw789 is offline
rw789 is on a distinguished road
Default Heated seats Problem.
I just bought my 03 H2. WOO HOO Now the fun part of fixing the issues I also bought.
When I press the seat heater bottons. The botton lights flash on and then off. No heat to seats. Fuse maybe? Or grounding issues?
Thanks.
Zoo
Old 08-10-2008, 12:18 AM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Default Re: Heated seats Problem.
If you tried it a second time and the light flashed on then off I don't think it would be a fuse problem. Not sure but maybe a relay issue. I can't tell you how they are wired though. Good luck and Congratulations on your new H-2
Old 08-10-2008, 03:28 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
I had the same problem , it was a bcm problem (body control module).
Sorry to say it was a dealer repair.
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 08-10-2008, 12:17 PM
Easy Ed Easy Ed is offline
Symptoms I had and the fix I did to my 03, replacing the module is a pain but not impossible.
Ed
http://www.elcovaforums.com/forums/s...ad.php?t=21588
Old 08-10-2008, 02:46 PM
HummerMann's Avatar
Had the BCM replaced under warranty with window problems. I keep an eye on Ebay because every now and then you see a new Hummer BCM advertised for around 199 and I plan on keeping this '06 awhile. The dealer price is more than twice that! My problem was with the door locks and electric windows acting erratically, particularly the rear window on my SUT. If you can find one it's just a matter of plugging in the wire bundles with their connectors. Mechanically/electronically, the BCM has been my only problem since I bought my '06 new.
Hummer, like nothing else
Old 08-10-2008, 04:32 PM
Not sure about the 06 but on the 03 the seat control module is in the drivers seat bottom and if rw789's problem is the seat module you need to "jump through some hoops" to get to it. It is under the seat with the seat adjustment motors, the heating elements along with the frame work. Manual even shows pulling back the bottom seat cover as part of the process to get to it.
Post from Klaus way back when.... http://www.elcovaforums.com/forums/showthread.php?t=13715&highlight=seat+control+modu le
Ed
Side note, didn't someone here mention that there was a "program update" for the seat module as a fix versus replacing it. Thought I read about that after I had replaced mine
Body control module http://www.gmpartcatalog.com/partlocator/index.cfm?action=getJointLocator&siteid=214551&cha pter=&sectionids=3,2413&groupid=10030&subgroupid=2 0033&componentid=60144&make=1000&model=Hummer%20H2 &year=2003&catalogid=1&displayCatalogid=0
Seat memory module http://www.gmpartcatalog.com/partlocator/index.cfm?action=getJointLocator&siteid=214551&cha pter=&sectionids=3,2413&groupid=10005&subgroupid=2 0107&componentid=61082&make=1000&model=Hummer%20H2 &year=2003&catalogid=1&displayCatalogid=0
