Old 08-19-2008, 06:38 PM
gmonroe gmonroe is offline
gmonroe is on a distinguished road
Default Cooling Fan Removal
Ok, so I am going to attempt my electric fan kit install tomorrow and I wanted to cover all of my bases before I tear into it. Do I need anything special to get the mechanical fan off? Everything else seems pretty straight forward, so I don't see any other problems. Feel free to give me ideas.
Old 08-31-2008, 06:46 PM
Default Re: Cooling Fan Removal
anyone? bueller?
Old 08-31-2008, 08:53 PM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Well can't give you any insight but wish you luck. Tell us how you made out. I have an 05 I want to switch over to electric fans.
Mike
Old 09-01-2008, 07:51 AM
Get a real large cresent or opened wrench. Place tool on big nut just between fan and pulley. Then take a great big hammer and hit wrench in opposite direction of the way fan turns as nut is reversed threaded so it will always be tightening itself on. The nut does not take a huge pop really, especially if factory placed lube or antisieze on the threads that are on the pulley which is made to the water pump shaft. Just a good firm pop and fan should jump loose.
If not clear ask Hummer service or leave me a follow up question.
Are you staying with factory RAD if so you will most likely have to cut metal tranny lines into so you can use rubber lines to splice back together to allow room to move things around to fit.
Depending on what fan setup you went with can determine what all you need to do the job. I used the same electric fan setup that is used on 2500/3500 series GMC trucks.
TAZ
Old 09-02-2008, 02:24 AM
Thanks for the heads up TAZ. I tried it a week or so ago and the bastard wouldnt budge. I read something about guys using an air chisel or something if it was stuck on. I in a holding pattern right now until I figure this out.
Old 09-03-2008, 06:21 AM
Be sure you are loosening in opposite rotation. On my 99 Silverado I had a stuck fan. I got a large chisel with large hammer so I could get a very clean start on the edge of nut. You do not want to crush nut threads onto the pulley threads. So finese is much more important than brawn. Once you have nut off be sure to lube well if you ever need to put mechanical fan back on. I carry my mechanical as you never know when electrical problems can arise. I have reused my mechanical on the Silverado before.
Oh also you can use some heat on fan nut just do not heat so much you swell the pulley threads creatin a tighter fit.
TAZ
Old 09-09-2008, 11:12 PM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
Don't waste your time, I replaced my fan with dual electric fans and there was no fuel savings plus the truck over heated once and once was enough for me, cant pull a trailer with the truck over heating.
Cheers
Good luck hope it works.
Old 09-14-2008, 10:12 PM
Gunzz's Avatar
So how did you make out with the fan removal and the electric fan installation? Let us know how it went.
Old 09-16-2008, 01:27 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Which fan kit did you get?
How much?
Where?
Sorry for all the questions
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 09-16-2008, 01:49 AM
I still haven't gotten my factory fan off. It's a mofo and really pissing me off. So I am going to wire it all up and have it setup to take to a shop to just connect the wires and install the fan assembly. I will keep everyone updated of course.
The fan kit I got was the flexalite kit with the dual fans and everything. (Most Hummer aftermarket sites have em) The price was around $500 give or take $50. I am going to wire it up all this time with the thermostat it comes with and put a kill switch for any reason I would ever get into water or something crazy.
As far as the above post saying "Don't waste my time", well sir, to each his own.
I know its crazy but it can't hurt. I don't tow anything bigger than my moomba outback so it's going to be fine.
Old 09-16-2008, 02:10 AM
They make a fan clutch wrench , you can rent at local auto parts stores
once you get that wrench in place on the nut, give it wack with a hammer!
(with the belt on of course) If that doesn't work, you can nudge it loose with an air hammer on the edge of the nut, but only if your comfortable doing that. Or you can bring a case of BEER to my house and I'll take off for you! Almost forgot to mention counter clockwise on that nut.
HCMI Member 50043
Old 09-16-2008, 02:13 AM
LOL, thanks for the offer. I keep hearing the air chisel but I sold all my shop stuff when I closed and I have beat the crap out of it. I am just tired of messing with it. I'll try again, but not today or tomorrow.
Old 09-16-2008, 02:15 AM
Good luck!!
HCMI Member 50043
