Old 09-09-2008, 11:23 PM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
Default F__king hummer cats
Anyone have a better fix for the typical Hummer cat problem other then replacing them with the factory ones?
Old 09-10-2008, 04:57 AM
Default Re: F__king hummer cats
There are aftermarket cats available. Check with your local muffler shop.
Old 09-10-2008, 04:35 PM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
I am on my second set of Dyna Tech High flow Cats and its less than 2 years and less than 40,0000 miles. I am now trying to look into cheator Sensors and just punch the cats through. Has anyone Had expierence in Aftermarket or "Cheator Sensors". They are new O2 Sensors.
B
Old 09-10-2008, 07:19 PM
iccon's Avatar
I was told by one guy to install a larger cat farther back on the hummer then relocate the O2 sensors that are behind the cats.
He also said the reason why they **** the bed all the time is they are to close to the heads and all that heat so they will just keep failing.
Old 09-10-2008, 08:53 PM
8500lbs's Avatar
This is something like I was talking about
http://www.yourhotcar.com/prod/Oxyge...Bypass/545967/
B
Old 09-11-2008, 02:54 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Their called MIL Eliminators, check at Summit.com
Also, are you running a Tuner or Programmer ??
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
