Old 10-12-2008, 05:46 PM
flyboy350 flyboy350 is offline
flyboy350 is off the scale
Question Tire pressure sensor
I have been getting a light and "gong" for tire pressure. I had this looked at and re-calibrated by the dealer. No change. It goes on and off and is annoying. Due to the fact that I have a US vehicle in Canada I don't get warranty. Can I disconnect the system? can I trouble shoot and figure out which tire sensor in not working and fix it myself?
Thanks for any advice.
Old 10-13-2008, 03:28 AM
HummerHippy's Avatar
Default Re: Tire pressure sensor
I wouldnt disconnect it if I were you. It dings once and then after a few miles the message goes away yes?
I used to get this in cold weather. I added air to the tires..perhaps 38 lbs or so, and the message went away on cold mornings.
29-Jul-2008
Old 10-13-2008, 06:34 AM
It continually goes on and off and is a pain in the A$$..... Have tried to over inflate a bit with no change....
Old 10-15-2008, 11:31 PM
Did you change tires or rims to effect the tpm sensors.
Did you do a tire rotation and not reset the system?
Either way...
You may want to reset TPM system anyway. It only takes about 5 to 10 minutes at the service station with a good air pump and your H3 service manual.
Disconnection of it not recommended.
Good Luck!
Old 10-16-2008, 04:55 AM
Either way...
Good Luck!
I wouldn;t disconnect either...but if I could find that little "ding" I would take a hammer to it!!!! Mine does it every morning and I had mine set to a "lower psi" before the "ding" goes off. It still fricken does it, but goes away after a few minutes of driving.
Old 01-20-2009, 02:24 PM
SELWA's Avatar
SELWA SELWA is offline
SELWA is on a distinguished road
I have the same thing happening. Just wondering why not dissconnect it? If your tires are low you should spot it and not need a sensor.
These are real machines!!
Joe Selwa
2007 H3 -
1995 H1 - SOLD
