10-25-2008, 03:32 PM
Changing the oil
3446 miles, love my H2 and not a single problem. Even though it says 45% oil life remaining, I'm going to change the oil before winter sets in. I like changing my own oil & using Mobil 1 Synthetic, even though I have a dealer coupon for a reduced rate. I picked up a filter and the oil and got under the beast.
It looks to me like the engine oil drain is the bolt (5/8 inch?) behind the aft end of the skid plate, but, am I blind or in need of stronger glasses? Where in the #!#* is the oil filter and how hard is it to get off? 6 qts with the filter?
10-25-2008, 04:14 PM
Re: Changing the oil
I'd advise against using synthetic until you hit 10K miles. The main reason for this is to allow the rings to seat. Synthetic is just too slippery until this process is complete. About 10 years ago, Porsche was installing it in all their cars from the factory, and still is today (Due to a licsensing agreement with Mobil 1). Suddenly, they had numerous cars coming back with engine problems. Porsche dealers now drain the oil before delivery and use standard 10/40.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
10-25-2008, 04:31 PM
The filter is at the rear of the engine, you need to remove the skid plate and you will see it.
I love doing my own oil on my cars, however I've only done the h2 myself one time as Its really a pain to remove the skid and then you will need to deflect the draining oil with a piece of cardboard or something as the flow will put oil everywhere on the undercarriage protection.
JiffyLube is my friend for the H2 as they do all the oil (Mobile1 synth) new filter, AND they do all the grease fittings for the whole vehicle for less than I would pay for a case of oil and filter on my own.
10-25-2008, 05:07 PM
The filter requires you to take the skid plate off to change it the easiest, unless you want to try and slash your wrist on the skid plate and burn your hand on the exhaust. I use 5.8 qts with the filter change. If you have a home air compressor and impact wrench you can do it in 30 minutes, otherwise I'd go to a Jiffy Lube or at the dealer.
I have to agree with Porschett on the synthetic oil. I had a factory new 1993 ZR1 Corvette that had the decal on the engine from the factory - ONLY USE MOBIL 1 SYNTHETIC. I bought mine in June 1993 and by that time the dealers were replacing the synthetic with regular oil as they got off the truck for break in and recommending not using the synthetic until you had 8,000 miles on the engine, because of piston ring problems. GM eventually came out with a bulletin on it. Boy, I wish I still had that car - it was F A S T!
Hummer, like nothing else
10-25-2008, 05:02 PM
BS!!! You can was synthetic at anytime regardless of the myths out there. I install it between 500 and 1000 miles on all my new vehicles. I just built a big bore stroker Harley V-Rod and fill it with Amsoil synthetic before it was even in the frame. I have yet to have to add any oil and it is making excellent HP.
2007 H2 SUV All-Terrain Blue - His
2008 H3 Alpha Graphite Metallic - Hers
10-26-2008, 12:31 AM
I wish you the best, but I stick with my recommendation. I have always changed the oil in a new car at 500 miles, to get rid of any metal shavings. I also wait until 10K miles to use synthetic. I'm pushing nearly 800BHP in the Twin Turbo and it's never used a drop of oil!
2008 GT2 Porsche
2009 DBS
01-28-2009, 04:13 AM
you are 100% correct....i had a dodge ram srt10 with the viper engine and before i could drive the car off the lot the service manager dropped the oil and replaced it wish 10/30....told me to come in at 1K to get an oil change, once again at 5K, and finally at 8K switched me back to synthetic.
01-31-2009, 01:20 AM
My 2007 H2 has 27,000 miles on it, and I use nothing but Synthetic Oil. No problems at all with it.
My 2008 has 8,000 miles on the factory oil, and still has 19% Oil Life Remaining. I dont change my oil until it says its ready. Changing oil at 3,000 or 4,000 miles is a waste of money. The way the engines are built now days, they are clean burning, they are not like the olden days where you put 3,000 miles on it, and the oil is JET BLACK........my 07 I can put 4,000 miles on it and its still clear. With my 08, I am should be able to get up to 9,500---10,000 miles on the factory oil before I change it. Everyone has there own preference, and I am sure people will bash me on this and say you need to change your oil sooner, but each and everyone has there own preference. Some like regular unleaded, others like Premium (which is all I use Shell V-Power) and I use Synthetic Oil.
For me........if your life oil meter says 45% your throwing your money away by changing it now.
10-26-2008, 01:53 AM
Synthetic oil is a personal preference. But calling engine break in a myth is not smart. Your engine may make good hp but you should at least break it in with regular, non detergent oil to promote ring seal.
Even Royal Purple now has a specific oil for break in. If synthetic was ok for break in, they wouldnt do create a product like that.
10-26-2008, 02:28 PM
I guess my H2 is unique b/c the oil filter is not that hard to get to. I always change my own oil and filter w/o any problems. I have never had to remove the skid plate.
10-26-2008, 04:01 PM
I never had to remove the skid plate but I agree it would be a little bit easier to get to the filter...but too much trouble to get the skid back on I am guessing...so I never tried...lol...
Jacksonville, FL
10-26-2008, 04:44 PM
I just go to Valvoline oil/lube center. They do a good job. $30 and its has new oil, new filter and full lube on all grease fittings. I just had them change out the front and rear diff fluid last trip. For the money its not worth my aggrevation.
2006 H2 SUT Fusion Orange LE
10-26-2008, 04:51 PM
sounds like a good deal...how much to change out the diffs...???
Jacksonville, FL
10-26-2008, 11:02 PM
$50/ diff, so $100 to do both of them. I only have 20K miles on her but the previouse owner flat towed the SUT behind thier camper bus. So i had no idea how many miles were on the diffs. Glad i did it, the lube looked a bit wore out and there were some metal shavings in there.
Hybrid Mode
