Old 11-13-2008, 04:52 AM
coach3rd coach3rd is offline
coach3rd is off the scale
Default HEEELLLPPP!!! H2 is now lower on one side
2005 H2 does not have air suspension. My son ran off the road the other night and hit something hard enough to break the rear shock in two. Both front and rear wheels went off the road and in a ditch. No body damage just seems to be lower now. Only the passenger side went off the road and now the H2 is 2 inches lower on that side (front and rear). I replaced the rear (passenger) shock and have looked all over underneath and cannot find anything else broken. Also there is about an inch of space now between the rear (plastic) bumper and the rear quarter panel. The ride is fine except for the 2 inch lean on the passenger side. What else do I need to look at. Is the frame bent?
Old 11-13-2008, 05:10 AM
twenty2's Avatar
twenty2 twenty2 is offline
Default Re: HEEELLLPPP!!! H2 is now lower on one side
well,1 of the questions i could prolly answer is that the rear bumper is bent causing that inch difference between the rear plastic bumper and the rear quarter panel.
everyone else will start to put their 2 cents into this matter pretty soon!
Brace yourself...
Old 11-13-2008, 12:17 PM
ck crossmember where rear of torsion bars insert into. most likely bent.
Old 11-13-2008, 03:52 PM
Please elaborate on the crossmember. Where is it located. I have stared and stared underneath and cannot find anything that looks out of the ordinary.
Old 11-13-2008, 05:32 PM
brad_p's Avatar
brad_p brad_p is offline
mid frame do you know where the torsion keys are at?
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 11-13-2008, 10:27 PM
Not familiar with the torsion keys. Could it be that I just need to adjust them? Would the force of striking something cause the passenger side to lower 2 inches? Is there a special tool needed?
Thanks for your assistance.
