Old 11-16-2008, 11:25 PM
mln2963's Avatar
mln2963 mln2963 is offline
mln2963 is on a distinguished road
Default Rear Wiper Replacement
Do you have to remove the spare tire to replace the rear wiper? If not, how do you replace it?
2006 H3. Slate Blue. Base. Automatic. Sun Roof. Roof Rail Airbag. XM. Tow
Old 11-17-2008, 01:13 AM
Viet Nam Vette's Avatar
Default Re: Rear Wiper Replacement
Just replaced mine... along with the fronts. Using the Rain X Lattitude.
The rear was a pain to get off. I just bent the old blade frame wide enough to slip over the "J" hook. The new one slides right on.
It is a pain to get off, but it can be done. The easy way is to remove the spare tire.
CAUTION* Make ure you put a nice thick bath towell or = on the glass to prevent yourself from snapping the bare arm onto and cracking or scratching the glass.
Turn the wiper on and stop it in the half way spot and slide the old BLADE down and proceed to cut or bend it with plyers.
It's either that or remove the rear tire. If any one else has and easier way ..jump on in..
Old 11-17-2008, 01:19 AM
fourfourto's Avatar
Did you get a RainX for the back I couldnt find them in a 12 inch ?
The front ones are beefy and work GR8.
Easy install Ive been through 3 in the back,funny thing I never use the rear wiper
Old 11-17-2008, 01:25 AM
They don't make a Lattitude for the rear ..It looks like an OEM Blade. Here's the Site selectin Chart..
http://www.rainx.com/Products/Wiper_...acturer=Hummer
I put Rain X Prep on the Glass and with the new blades it works sweet. Consumer Reports rated Rain X number 2 but it beat out Number 1 Valeo 600 as it lasted 6 months.
Don't know if this link will work as you need a subscription..
http://www.consumerreports.org/cro/c...rs-ratings.htm
Old 11-17-2008, 01:28 AM
RazM's Avatar
RazM RazM is offline
You don't need to cut or bend anything or remove the tire, just put the rear wiper on the fastest setting, remove the key from the ignition and just open your door when the wiper is in the top position (that'll stop it), then just pop it off and replace. It's a little hard, but not impossible.
Old 11-17-2008, 01:48 AM
I might have smoked to much Crack That day... But I found it hard to get that sucker to come off my 07 With out some "C-4" or vise grips
Old 11-17-2008, 02:01 AM
RazM's Avatar
It's definitely a bitch to get off, took a few mins of trying and trying but I eventually got it unhooked. Getting the wiper in the right position is fun too
