Old 12-18-2008, 02:11 AM
Rockyot Rockyot is offline
Rockyot is off the scale
Default Engage Rear Locker in 4-Hi on H2?
has anyone come up with a switch or rewire so that i can engage the rear locker while in 4-Hi?
Today is the best day you are going to get. Enjoy it and lift somebody up with you.
Old 12-18-2008, 02:26 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Engage Rear Locker in 4-Hi on H2?
Can i ask why you would want to. Not a good idea cruisin down the road to be locked
Old 12-18-2008, 02:37 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
I also have to ask..... there is really no reason to engage the locker other than for crawling through the very rough stuff.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-18-2008, 06:10 PM
In the sand at Pismo Beach it would be nice to have the back end locked up. No need for 4-Lo. Locked works well in the snow too. Maybe it is just me??
Old 12-18-2008, 08:23 PM
HUMTECH's Avatar
Actually locked up is worse in the snow, tends to want to fishtail. My jeep is full time locked in the rear and tough to keep straight when in snow
Old 12-18-2008, 11:02 PM
Thanks for the heads up in the snow. In my Rubicon it was helpful in the sand in 4-Hi.
Old 12-19-2008, 02:06 PM
MVR 155's Avatar
It will also cause the front end to shove badly at low speeds while turning.
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 01-01-2009, 06:26 PM
Bronze's Avatar
Bronze Bronze is offline
Bronze is on a distinguished road
Most H1 and H2 Hummer have a feature where If you require additional traction without engaging the HI-Lock or Lo-Lock simply place your left foot on the brake then give slight power to the right gas peddle. It will transfer traction to the wheels that have traction and lock the wheel that is slipping.
Old 01-03-2009, 09:39 AM
HUMTECH's Avatar
Well thats half right, the H2 is equipped with open front and rear differentials with the eaton e-locker in the rear only. The H1 is equipped with torsen differentials front and back which allow power transfer with either driver input using the brakes or automatically if equipped with tt4, later models of the h1 were available with lockers front and rear as an option
