Old 12-22-2008, 06:46 PM
Lauxmi01 Lauxmi01 is offline
Lauxmi01 is on a distinguished road
Default Hidden CB mount idea
Tell me what you guys think, it clears the mic, which is then clipped to the back of the console. I want some feedback before i drill holes for the antenna / power / pa. Also, if the console muffles the cb speaker to much I may just hook up the external speaker and put that up hidden under the dash. Thoughts?
Old 12-22-2008, 09:36 PM
Default Re: Hidden CB mount idea
That is a good fit. The only drawback and its minor is your reach back for any control changes will be crampy. If your a channel 19 steady thats a non issue so sound and extra wire slack for working are your only concerns
Old 12-22-2008, 11:17 PM
Desert Dan's Avatar
Looks good
Are you going to drill a hole for the mic wire or just run it under the lid when in use?
I had a similar set up in my YJ Jeep
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 12-23-2008, 03:58 AM
Crash ?'s Avatar
Crash ? Crash ? is offline
Heck if there's room go on and put a full size CB in there.. I hadn't thought of stuff in the CB in there.. Of course mine is full of other crap..
Rob
Old 12-23-2008, 10:47 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Did you check out the Cobra Hidden CB?
http://www.elcovaforums.com/forums/s...light=cobra+cb
Old 12-28-2008, 08:01 PM
Handhelds have same 4 watt power...
http://www.google.com/url?sa=t&sourc...YHI910Eq-j2uJA
