Old 12-30-2008, 09:42 PM
Yetti Yetti is offline
Default Ok which one of you has had this?
since I live in Michigan its only fair I tell you have had ice problems. but within that this is not one of them times.
My H2 is an `04 Adventure and has only 32,000 miles, it has been making a weird clunk/pop noise under the drivers side floor. it like someone smacks it with a hammer while your going through twisting types of bumps. I don't know if its a cab mount or what?
FYI I already took a breaker bar and tightened all the lower control arm bolts and skid plate bolts. I couldn't find anything really loose.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 12-30-2008, 10:41 PM
brad_p's Avatar
brad_p brad_p is offline
Default Re: Ok which one of you has had this?
mine did that on the passenger side. Maybe try greasing everything mine stoped after i did that.
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 12-31-2008, 03:13 AM
mikejr's Avatar
mikejr mikejr is offline
There are quite a few threads on this noise and I dont recall what it was, thinking it was either the body mount bolts or something to do with the suspension. My 06 was doing it just before I traded her in for an 08. Use the search and you will find out what the issue is.
2009 H2 Silver Ice LE
Old 12-31-2008, 04:08 AM
"OIL CANNING" My first 03 did this...don;t remember the fix though.
Old 12-31-2008, 04:52 AM
jroman201's Avatar
jroman201 jroman201 is offline
jroman201 is on a distinguished road
i htink mine is in the shop for the same issue right now...body frame bolts is what they tell me...
Jacksonville, FL
Old 12-31-2008, 04:36 PM
HummerMann's Avatar
My '03 did the same thing, only I would describe it as a muffled pop when I was on rough roads or offroading. The dealer said it was the floorboard, due to the softness of the body mounts and lack of chasis and suspension lubing.
It all started after an offroading excursion when I got lots of mud everywhere and had to get winched out. I just got out my old service record from '03 and it says they "secured all body mounts and cleaned, lubed and greased the chasis." It never did it again after that.
Hummer, like nothing else
Old 01-02-2009, 06:48 PM
Cool, I'll have to try that when it warms up a bit. I was going to rip the rock rails and the landing skids off to see if they have been moving too.
Yetti
www.wegotmud.com
www.glfwda.org
