Old 01-19-2009, 03:16 AM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Default Siphon pumps
Ok so I know most of you guys here like to do your own work on your vehicles, so was wondering what everyone uses to siphon lubricants from the rear and front diffs??
Old 01-19-2009, 03:24 AM
Intercooled's Avatar
Intercooled is off the scale
Default Re: Siphon pumps
I had the shop do it. Isnt there a drain plug?
2006 H2 SUT Fusion Orange LE
Old 01-19-2009, 03:34 PM
HummerMann's Avatar
I use a 110v marine oil change pump and just stick it in the fill hole. You can find them on Ebay. Mine is an old Marine Sunstrand with a 2.5gallon tub. Just make sure the fluids are warm before you pump. It's similar to this type of product -
http://www.hodgesmarine.com/ProductD...012&click=7482
Hummer, like nothing else
Old 01-19-2009, 07:08 PM
Gunzz's Avatar
Very cool. Has to be alot easier then using those hand pump models. I saw the hand versions at Harbour Freight for under $15.00 but was thinking that pumping, holding the draw tube in the axle, and making sure the exit hose stayed in the bucket might be kind of difficult.
I like the electric model much more.
Old 01-20-2009, 12:52 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Um, yeah. Both diffs have a drain plug
