Old 01-24-2009, 12:52 AM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Default burnt bulb??????
Ok went out to truck after work today and found I had no rear lights on left side of truck. No bumper light, no regular light and no left side marker light? Is this a bulb out to make all these not work? Directional work fine and brake?
Old 01-24-2009, 01:34 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: burnt bulb??????
There is a connector for all the lights for each side under the left rear of the truck. Check and make sure it is fully seated
Old 01-24-2009, 03:17 AM
WHOSNEXT's Avatar
connector seem fine,bulbs and fuses are good, when i press on the brake the side marker light comes on? anything else i can check?
Old 01-24-2009, 06:25 AM
HUMMERICH23's Avatar
HUMMERICH23 HUMMERICH23 is offline
HUMMERICH23 is on a distinguished road
I just had the same thing happen to me the past month and just got if fixed this week. I noticed a month ago which means it might have been out longer the left tail light and regular light out but my top rear roof lamp was still working. I went to the dealer and they replaced the bulbs in each lamp and worked fine for like 1 day then they flickered and burnt out later that day. Took it back and they said it was a faulty wiring harness and something else so they replaced the wiring and bracket for each the tail and regular light. Now it works fine. I dont know if its the same thing going on for you but i got mine fixed and covered under warranty .
Old 01-24-2009, 03:04 PM
WHOSNEXT's Avatar
thanks for the info, made a appointment with dealer today.
Old 01-24-2009, 08:01 PM
Bimmer9938's Avatar
It's the fuse under the hood, not in the dash. Had the same thing happen.
