Old 03-03-2003, 01:39 PM
Peyton77 Peyton77 is offline
Peyton77 is off the scale
Does anyone know if you can get TV signals with the Alpine system , or do u need a seperate tuner attacement? I dont know the Part number but it is a widescreen 6.8 in monitor, I know it has 3 inputs, i was thinking about putting in the rear view cam, ps2 (more for dvd playing), and nav system, but i forgot to ask if you can get TV too?
Peyton
WWW.LANDMARKBANKONLINE.COM
WWW.GIANTBANK.COM
Peyton
Old 03-03-2003, 11:01 PM
TBarrow TBarrow is offline
TBarrow is off the scale
I have not found an antenna that works at all times. They tend to fade in and out. Picture pushing your home tv down the street with just rabbit ears. that is the quality as you ar always moving. I have a dual mast amplified 54" antenna but dvd's work best
Old 03-04-2003, 01:21 PM
JayH JayH is offline
JayH is off the scale
The monitors you have will reproduce whatever standard NTSC signal you feed it; ie;dvd, vcr, off-air or satellite. The feed will require a tuner to provide that compatability. If you live in a metro area it will be harder to maintain a strong off-air signel due to all the ground interference/buildings, trees and any other structure. There is an in-motion sat. system made for SUVs that is similar to the units used on RVs. Jay
Peyton
WWW.GIANTBANK.COM
Peyton
Old 03-04-2003, 12:31 PM
SLOWPOKEH2,
4? where did you put all of them.
Peyton
WWW.GIANTBANK.COM
Peyton
Old 03-03-2003, 09:49 PM
SLOWPOKEH2 SLOWPOKEH2 is offline
SLOWPOKEH2 is off the scale
THEY TOLD ME AT THE AUDIO STORE I BOUGHT MY ALPINE MONITORS THAT I COULD BUY THE TUNERS BUT THE SIGNAL WOULD FADE OUT DEPENDING ON WHERE U WERE AT. I JUST HOOKED MINE UP TO AN XBOX (PLAYS DVDS AND GAMES THATS ALL I NEED) THE PRICE 4 EACH TV WAS 750.00 I GOT THE 4 500.00 EACH AT TWEETERS IN CRYSTAL LAKE IL.
