04-08-2009, 01:25 AM
Help with NAV install
I have a 05H2 with a 6disc in-dash unit. I bought a Nav unit and installed it.
It was working but didnt sound as good as the 6disc. After i turned off the key it went into "theftlock activated" mode. I went to the dealer and made an appointment to have it unlocked for this Fri. While I was there they looked in my glove box and saw that i had a y91 code. They said that this was the "Lux" setup. After that, they looked at my head unit and said that it was a "non lux" unit (10377287). Will it work and sound as good as before?
Im confused...what should i do??
04-08-2009, 01:38 AM
Re: Help with NAV install
NOPE, you need to get a Y91 NAV UNIT. Sell this unit and then re-buy the Y91. It is a MUST HAVE with the Y91 option.
CURRENT HUMMER:
Number# 11  2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
04-08-2009, 01:50 AM
Even though it worked? Sell and buy the "lux"?
04-08-2009, 02:04 AM
The non-lux radio was for a non BOSE amplified system. The sound is 100% different with the proper Y91 option. If you use a non-lux nav unit in a lux equip system (Y91) it is just running off the radio power and not using the amp.  therefore sounding like crap! sorry non lux guys.
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
04-08-2009, 03:37 AM
Now I read somewhere that no 05's came with the "lux" amp only "premium" amps....does anyone know if this is true? If so, then is my non-lux nav good?
04-08-2009, 02:02 PM
gatorsdogg, bottom line is if you want it to sound AS IT should and IF YOU have the Y91 OPTION you MUST GET THE PROPER RADIO. The made them different for a reason. Contact your dealer for specific details.
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
04-09-2009, 01:48 AM
Get the part number off the amp. Than call GM back to see if they match up. If not, maybe you can get a different amp in there cheaper than you can for another NAV unit.
04-09-2009, 03:07 AM
Hey guys, sorry I'm jumping into this late, this was my Nav. I have an '05 LUX H2, this was taken out of my truck because I wanted bluetooth, a direct AUX connection (non-ipod), XM Traffic/Weather, etc....honestly biggest mistake I could have made because the idiots that installed the new crap made things worse, but afterwards I found out there was no turning back...but that's off-topic....so anyway....
So how can an OEM NAV unit from a LUX '05 H2 (mine) not work in a '05 H2 Lux w/ a 6CD Changer (gators) as a direct swap. This isn't making any sense?
I have the BOSE system (at least every speaker in the rig says it's Bose)...and the VIN and all the documents when I bought it say it was all factory included.
Anyone?
04-09-2009, 03:35 AM
Anyone?
Tully, makes no sense to me. However I thought his radio was a NON Y91 Radio???? Do you have the Y91 option??? You must if it is a Lux? However the 6 disc changer may be the key!!!
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
04-09-2009, 03:35 PM
After emailing Gator last night, sounds like we both have Lux '05 H2's....so no, this doesn't make any sense?
04-09-2009, 04:01 PM
Tully, the Radio part number is a NON-LUX head unit without the Y91 code. Are you certain you have the y91 code for the dealer said it was not????
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
Hybrid Mode
