Old 05-23-2009, 05:44 AM
6.2 6.2 is offline
6.2 is on a distinguished road
Default 35s with no lift??
Will 35s fit rub with no lift up front??
Old 05-23-2009, 02:30 PM
2of4 2of4 is offline
2of4 is off the scale
Default Re: 35s with no lift??
If you are driving an H2. 35s are stock so they should fit.
2008 SUT
Old 05-23-2009, 02:35 PM
Boss Hoss's Avatar
Boss Hoss is off the scale
Dont listen to this smart@ss. Everyone knows you can run 35s but they will rub really bad unless you install the parallel centralized stabilization lift kit. Best of luck !
Old 05-23-2009, 04:07 PM
CONRAD II's Avatar
[quote=Everyone knows you can run 35s but they will rub really bad unless you install the parallel centralized stabilization lift kit. Best of luck ![/quote]
Thats just great!!! I've been running 38's with a 6 inch lift & NO PARALLEL CENTRALIZED STABILIZATION. My rig must be totally screwed now
66' VETTE STINGRAY
07' Z06
Old 05-23-2009, 06:18 PM
IRA51's Avatar
IRA51 IRA51 is offline
the no sarcasm answer is 315/70/17 and 35/1250/17 are close enough in size to use without any worries .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-23-2009, 08:01 PM
hummerpartsman's Avatar
hummerpartsman hummerpartsman is offline
hummerpartsman is on a distinguished road
THERE IS NO RUBBING WITH 35'S WITH NO MODS NEEDED
Old 05-23-2009, 08:19 PM
6.2 6.2 is offline
Excuse my ignorance, I thought the stock tires were 33in. I just want a little more tire but I have rear air susp and don't want to have to mess with the sensors or anything.
Old 05-23-2009, 08:29 PM
Boss Hoss's Avatar
Nah youll be fine as your running the Fabtech lift. The rule is:
35in tires=parallel centralize stabilization lift
38in tires=Fabtech suspensionlift
I know that was a close call for you but no worries
