Old 06-03-2009, 03:41 AM
ISAS ISAS is offline
ISAS is on a distinguished road
Default Auto Climate Control
My auto climate control in hot weather will switch automatically to the recirculation mode and then back to normal mode...only does it if weather is 85 degrees or hotter outside...no problem with heat...my uncle has a escalade with same issue...any help would be appreciated
Old 06-03-2009, 08:41 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Auto Climate Control
mine has alway done it at over 95 degrees ,but as long as it blows cold it's all good with me .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-04-2009, 02:32 PM
HumminNBoatin''s Avatar
I have never noticed that. Also keep in mind when you set your memory it saves whatever HVAC settings you have at the time.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 06-05-2009, 12:27 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Its normal. In auto mode it will control mode doors, recirc door and the blend doors to keep cabin at the temp setting you have selected
1998 Chev Z71
2007 Chev Trailblazer SS
Old 06-22-2009, 09:39 PM
Is it normal for the air not to be cool? The dealer I purchased it from (GMC) stated it needed and actuator. What do you think?
Old 06-23-2009, 12:27 AM
HUMTECH's Avatar
Depends on the in cab temperature, if its hot in the cab the air from the vents should be cool, as it cools down in the cab the air delivery temp will adjust to keep the cab at the temp you have chose to set it at. Are any codes set in the hvac module?
1998 Chev Z71
