Old 06-15-2009, 06:24 PM
H2inMD H2inMD is offline
H2inMD is off the scale
Default Are headers worth it?
ok, the existing manifold has to come off due to broken bolts.
Should i reuse it or put headers?
What will increase low end torque .
what brands.
this is a 2003 with 95,000 miles
thanks
Old 06-15-2009, 06:47 PM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
Default Re: Are headers worth it?
I have heard that the short tube headers are not that much of an improvement over stock. These being the edelbrock, BBK, and JBA. However, I have heard that the long tube headers do improve the numbers. The only version of a long tube header i have seen are the Dyna Tech Headers. These are the set of headers that i choose to go with and I have been happy with them. They also have high flow cats. as an option. I have them but i have also melted a set. Next I am going to bypass O2 sensors and drill them out.
Hope this helps.
B
all exhaust
http://www.summitracing.com/search/year/2004/make/HUMMER/model/H2/Department/Exhaust/Engine-Size/6-0L-364/?Ns=Rank|Asc
Dyna Tech
http://www.summitracing.com/parts/DT...DTC-115-841350
Old 06-15-2009, 07:17 PM
IRA51's Avatar
IRA51 IRA51 is offline
Bassani ,works well and Dynatech. but unless you have a supercharger or bigger cam and ported heads and a tuned computer the increase will be minimal. cost to power ($1500.00 with cat's ) on a stock engine is not good ,but if you do the mod's down the road headers realy pay off. the exaust alone won't hurt your high milage trans ,but heads and cam with a cumputer tune or a blower will fry your trans quick .if you haven't done a high preformance trans rebuild with a good torque converter yet at 95k ,you might want to do that first B4 engine mods to increase engine output . ya gotta tinker the Bassani ,the Dynatech's are the way I would go . if ya got the $$$$ cash to spend headers are alway an improvement over the stock exaust manifolds .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-15-2009, 07:24 PM
H2 Bill H2 Bill is offline
DON'T get the Edelbrock!! They don't stand behind their headers, even though they say otherwise. I learned from experience after replacing 2 sets at my own expense (broken welds at the collector). I went to the Borla that have a lifetime guarantee.
1994 Chev Suburban Blown
Old 06-15-2009, 07:49 PM
IRA51's Avatar
Bassani BabesOrder PostersContest InfoBassani High Performance Headers?Unsurpassed quality and fit, superior materials and expert craftsmanship.
?Mandrel bent 14 ga. Carbon steel primary tubes for durability.
?Exclusive ?Extractor Collector: induces a scavenging effect and further improves performance.
?S.S. Comp TM Stainless Header Gaskets cure header leaks.
?Gasketless Ball and socket connectors.
?Standard finish is industrial chrome. High temperature ceramic coating is optional.
With over three decades of design experience and maximum performance, Bassani has learned what works and what doesn?t. We have the ability to develop product designs to optimize performance and the technical expertise to implement these designs. When it comes to header design, experience does make a difference.
We currently offer a line of emissions legal headers for a wide-range of cars, trucks and SUV?s. Bassani?s headers feature mandrel bent 14 gauge mild steel primary tubes, our exclusive ?Extractor Collector? and gasketless ball and socket connectors. We build every header the best way we know how? in-house. We do all of our own tube fabricating, bending, welding, etc? when it says Bassani? it means Bassani BUILT! Every header application comes complete with premium gaskets, nuts, bolts, hardware and detailed instructions. Most applications are available in industrial chrome or hight temperature ceramic coating.
Click here to learn the difference between COATED and CHROME.
MAKE YEAR APPLICATION ENGINE COATED CHROME
you have.
-- Thomas Jefferson
Old 06-15-2009, 07:59 PM
IRA51's Avatar
AVAILABLE CERAMIC COATED!!
(Headers only, inside & out)
Just add part number 90-00100 to your order.
($260.00 additional per set)
GM Silverado / SierraTruck & SUV Headers
07-Up Now Avaliable
Ford F150 Truck & SUV Headers
H2 Hummer Headers
07-Up Now Available
Dodge Ram Hemi Headers
Trailblazer
SS Headers
07 -Up Toyota Tundra Headers
SSR Headers
SuperMAXX
Replacement Parts
SuperMAXX Stainless Steel Exhaust Systems are engineered to give your car winning performance both on the track and offroad. Designed to be a direct replacement fit for restrictive factory exhaust and catalytic converter systems, these systems are a great way to get that extra power you are looking for.
If you still want more power, our testing has shown the SuperMAXX System's increased flow, actually multiplies the effects of other power add-ons like intake improvements, supercharging, and cat back systems by allowing them to work to their full potential.
?Racing inspired long-tube designs
?CAD-designed Aero-flow collectors with low profile, 4-bolt, leak-free connection
?Uses factory sensors
?Quality stainless hardware for long life
?Unique NASCAR-style merge on many models
?Jig-located mounting brackets and flanges for direct bolt-on fit
Critical aspects of header and exhaust function are carefully considered in the design of Dynatech components. Years of race winning experience along with continued development and testing ensure every Dynatech product delivers real performance and power.
Superior design and skilled Dynatech craftsman are responsible for Dynatech?s outstanding quality ? a difference that can be seen at first glance.
Beyond simply fitting the application, SuperMAXX Systems are engineered to produce power ? real, usable, seat of the pants power. Our systems are dyno proven to substantially increase horsepower and torque throughout the rev range. An increase that will be sure to put a smile on your face.
Laser-cut flanges, flat ground welds and gussets (on some models) ensure great fit, a leak-free seal and long life.
Mandrel bends and joints provide smooth internals and superior flow.
Careful consideration to port matching and flange / tube exit angle enhances power.
Tube length in every model is optimized for power output and space constraints. Equal length tubes are utilized when possible for increased torque and power.
NOTE: These products are intended for racing and off-road applications. Not legal for sale or use in the state of California, nor in states which have adopted California emission standards.
A-FAB Corporation
Dynatech ? 975 Hyrock Blvd ? Boonville, IN 47601 ? 800-848-5850 ? Fax:812-897-6264 ? sales@dynatechheaders.com
media & sales center | career opportunities
you have.
-- Thomas Jefferson
Old 06-25-2009, 02:57 AM
zacknolden zacknolden is offline
zacknolden is on a distinguished road
Hmmm... I did some research. Is it true that the Bassani x pipe is modular and comes with legs that fit the stock manafold.
