Old 08-15-2009, 05:41 AM
transam95's Avatar
transam95 transam95 is offline
transam95 is on a distinguished road
Default Vizualogic Help Please
Im looking to get the A1000 or the A2000 for my 05 Hummer H2. Now here is my question. I have a avic 90BT touch screen headunit installed that has navigation and dvd capilities. Is there a way to have the 2 headrest units play what is playing on the headunit?? Thanks guys in advance
Old 08-15-2009, 05:48 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Default Re: Vizualogic Help Please
GOOD LUCK!
I tried and gave up. I was going to add a monitor on the third row seat. Bought the monitor and made a wire harness that went from RCA to the 8 pin mini-din,. Bought an 8 pin mini-din splitter and tried it out before I cut the headrest opened. I was happy to see at first it worked but than realized that the monitor I jumped off of would not support the video when the third monitor was on. It cannot support more than two video screens on at a time RATS.... There are some aftermarket co's out there that do sell video amplifiers so that you could run up to 6 monitors but I gave up and did not try to do this mod. Let us know if you do it and please post some pics. I have the 7" monitor still sitting in the box waiting for me to try again!!!
Old 08-15-2009, 06:01 PM
For anyone that still wants to try, I have the pinout diagram for the Vizuologic Advantage system
On the Mini_din, there are 8 posts and the outside ring(shield) is a ground. For reference, if you look at the mini-pin staight on, there will be 3 pins on the top row, 3 on the middle row and 2 on the bottom row. Pin 1 is the bottom left pin, #2 is the bottom right. #3 is the middle left, #4 is the middle pin in this center row and pin #5 is the right pin on this row. Pin 6 is the upper left pin, Pin 7 is the center pin on the top row and pin 8 is the right pin in the upper row. I have confirmed these connections but strongly suggest you do the same just in case there have been any spec changes I am not aware of)
Pin Description Wire Color
1 +12V Black (shiny)
2 Audio R + Blue
3 Audio L + Green
4 Video Red
5 Video Ground Black
6 IR Brown (shiny)
7 Parking yellow (Shiny
8 AV Select Purple (Shiny)
On the other end of the harness (the monitor side, the white wire is the Audio left ground and the yellow wire is the audio right ground. These both are connected to tyhe mini-pin ground shield.)
Old 08-16-2009, 12:12 AM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
YES
It can be done I have 4 visualogic 9 inch headrest monitors in mine with amplifiers and they work great. They also have dual input and can work with wireless headsets (works great for kids). I will see and snap a pic for you. Never the less you will need amps for the monitors. Mine came with them.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 08-16-2009, 01:00 AM
H2R's Avatar
H2R H2R is offline
PIC
2013 Sierra Denali
2012 Yukon Denali
Old 08-16-2009, 01:12 AM
H2R's Avatar
H2R H2R is offline
Also I went off road this past week. da#n messed up the tire shine!
2013 Sierra Denali
2012 Yukon Denali
