Old 10-18-2009, 09:07 PM
Astroboy Astroboy is offline
Astroboy is on a distinguished road
Default Heat and recirculate at same time?
My climate control is almost always set to "AUTO" at 70F degrees. During the hot summer days with AC on, I engage "RECIRCULATE ↻ " to rapidly cool down the interior air.
However, I can't seem to be able to do the same thing when the heater is on. When the outside is cold and I turn on the heater, the heater takes in the cold outside air, warm it up and send it inside. Why can't I have the heater to take in the already-somewhat-warm interior air and heat it even warmer?
When my heater is on and I press "RECIRCULATE ↻ ", the computer seem to override and disengage it in a few seconds.
Is this normal?
Is my recirculation (blend door) broken?
I have 2008 H2.
Thanks in advance.
Old 10-18-2009, 09:12 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
Default Re: Heat and recirculate at same time?
well, if it wasn't SNOWING outside today I would go out and check mine...October 16 and snow in NH, what a dump... lol
I have an 09, will give it a check tomorrow as it looks like the heater will be on for the next 7-8 months!
Old 10-18-2009, 10:06 PM
dochummer's Avatar
Yes, for a 2003 model. Really annoying... but I guess it's to keep you from fogging up your windows...
'03 H2
Old 10-18-2009, 11:30 PM
Do you mean YES, that your 2003 can HEAT and RECIRCULATE at the same time?
In that case, I envy you.
My other car is VW GTi w/ manual climate controls (cable operated).
I'm able to:
- set the TEMP analog dial to "hot" (heater on)
- switch on "recirculate"
- switch on AC
By turning on the heater, AC, and recirculate, all simultaneously, it would give me a dry warm air (w/ its moisture ridden by the AC). It would keep me warm and de-fog all my windows.
I want that.
Old 12-26-2009, 01:11 AM
Bump -- Just wanted to revisit and clarify this issue.
Both 'recirculate' button and 'AC' button soon deactivate in a few seconds every time I press and try to activate in the last few month (during this winter).
(I have 08 H2, and it has auto-climate-control system with separate interfaces for the driver, the navigator, and the rear passenger.)
- Is it possible to heat the cabin air and recirculate at the same time?
- Is it possible to heat the cabin air and "AC" ON at the same time?
I'm asking this because H2 is my 1st vehicle with auto-climate control system. All the vehicles I owned before were equipped with manual-climate control, and I was always able to perform both above scenarios.
'heat' + 'recirculate' -> for rapid heating
'heat' + 'AC ON' -> for dehumidifing
I'm wondering if other fellow H2 owners are experiencing the same, and this is the norm, or if my climate unit (especially the blend door) is broken.
Thanks.
Old 12-26-2009, 06:52 PM
pdxrealtor's Avatar
I just went out and tested mine... 2006, no climate controls in the back.
Recirculate would not stay on in any scenario when the system was in "AUTO" mode.
A/C could be turned on or off in "AUTO" mode.
Re-circ.. of course... could be used while not in "AUTO" mode.
Hope this helps.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
