Old 11-03-2009, 03:49 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Default FS: PML Diff Cover NIB
New, never installed, still in the box, black powdercoat (see pic below). $150 shipped CONUS. Paypal or USPS money order. PM me if interested.
Features
  • Increased oil capacity for cooler temperatures
  • Sand-cast aluminum with raised cooling fins
  • 3/16" thick wall construction to add strength
  • 3/8" gasket flange won't bend distort
  • Machined gasket surface for a secure seal
  • Oil changes without removing the cover
  • Magnetic drain plug for easier fluid changes
  • Mounting hardware provided
Old 11-04-2009, 03:51 AM
Marauder Marauder is offline
Marauder is on a distinguished road
Default Re: FS: PML Diff Cover NIB
Wish I would have waited to get mine. I purchased the same one. Very nice. Looks great. It makes a bigger difference than you would think. Great price.
Old 11-05-2009, 01:12 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Do you have to remove any additional parts to install this?
Also is the gasket included?
Old 11-05-2009, 04:45 PM
No parts removed. The panhard bar (or whatever it is called) is right in front of the cover. Bur you can get to the cover without removal. I did it on a lift. May be different on ground.
No gasket needed. Very light bead of rtv is all thats needed. Just smooth out with your finger making sure you get 100% coverage. I used black rtv.
Old 11-05-2009, 06:43 PM
TXSUT's Avatar
Thanks Marauder, much appreciated.
Old 11-07-2009, 04:45 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Great Price! I have the same 1 but not powder coated. I replaced the Dif fluid with Royal Purple and loave it! Someone should snap that up!
