Old 11-20-2009, 04:31 PM
wingn69's Avatar
wingn69 wingn69 is offline
Default wiper hose location help
Hey guys I checked the search but didn't find my issue. I just had to have my windshield taken out and resealed water leaks around the windsheild.
think the hose came lose when the windshield was worked on I checked from the tank to firewall but I think the hoses have come lose from the wiper system, how do I get to the hoses to check to see if thats the probelm. I cant figure out how to get the air covers / molding off with out breaking something to check the connection to the nozzles. I am hobby wrench turner so keep it simple please. thanks
Old 11-20-2009, 05:19 PM
Easy Ed Easy Ed is offline
Default Re: wiper hose location help
The fake air covers just pull off. Should be 4 spring clips (like the ones holding the center console in but larger), just get a good grip on them (the covers) and pull up. Remove the wiper arms by moving the small locking lever and sliding the arms off. The rest is more spring clips and "push retainers" and a couple screws. The wiper hose is on the passenger side.
Old 11-20-2009, 07:58 PM
wingn69's Avatar
Thanks for the help I will give it a try over the weekend.
Old 11-20-2009, 08:40 PM
Removing wiper arm is done by pulling up in the locking tab.
Attachment 51804
Pulling up locking tab.
Attachment 51805
Removing wiper arm, got to bend at a 90 degree, it helps.
Attachment 51806
Pulling off fake air intake.
Attachment 51800
Backside of fake air intake showing clips.
Attachment 51801
Fake air intake removed showing 1 of 2 screws to remove. (one will be under other side)
Attachment 51802
Passenger side of truck, just to the left of the windshield washer reservoir you can see 1 of the 2 push clips that needs removed, other will be on drivers side.
Attachment 51803
Got to pull up on the cowling to break loose the spring clips (4, I think) that hold it on just like the fake air intakes clips. Just take your time and you should be okay.
Attachment 51807
On the passenger side is where all the fluid lines come together.
Attachment 51808
Hope after all this you find the leak and can fix it and then reverse the whole process to put it back together. If you break one of the spring clips on the cowling, remove one from the fake air intake and use it to replace the broken one on the cowling. It is much easier to pull the fake air intakes to replace one of their clips. And just incase you do break one, just give me a holler, I bought a pack of them and would be glad to send ya what ya need clear over there in Sulzbach-Rosenberg, Germany
Good luck, Easy Ed
Old 11-20-2009, 08:49 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
If the company that replaced your shield caused this, have them come back out to fix!
Old 11-20-2009, 09:37 PM
wingn69's Avatar
Easy Ed, dude your the best thanks for the photos and step by step I think I just might be able to do this myself.
I would go to the repair shop and have them fix it but its a 250 km trip and a tank of gas just to reconnect some hose so if i can fix in my driveway I save some time and money.
