Old 11-26-2009, 05:47 PM
Trinity2427's Avatar
Trinity2427 Trinity2427 is offline
Trinity2427 is on a distinguished road
Default Installing an Ipod Lock Pick on my 08 SUT
Hi All,
In this post I will detail the installation process of a Coastal Tech Ipod Lockpick in my 2008 SUT.
Ipod Lockpick:
Note: Turn off the ignition and take out the keys before proceeding.
1. First open and empty the glove box. When you look inside the box, on the top right is a plastic tab that you can push up to allow the box to swing all the way open - down toward the floor. You will see the factory XM unit on the right side of the cavity behind the glove box.
Old 11-26-2009, 05:50 PM
Default Re: Installing an Ipod Lock Pick on my 08 SUT
Here's the XM unit.
Old 11-26-2009, 05:51 PM
BTW - Here are the contents of the Ipod Lock Pick kit:
Old 11-26-2009, 05:52 PM
2. Remove the large black plug from the bottom of the XM unit (the instructions tell you to remove the XM unit from the cradle but there is no need to do that).
Old 11-26-2009, 05:54 PM
3. Plug the black connector from the factory harness into the female connector on the Lock Pick harness.
Old 11-26-2009, 05:55 PM
4. Plug the male black connector on the Lock Pick harness into the XM unit.
Old 11-26-2009, 05:56 PM
5. Check the settings of the switches on the Lock Pick unit - on my 08 SUT with XM & Nav this is the correct setting:
