Old 12-12-2009, 02:07 PM
05h2sut 05h2sut is offline
05h2sut is on a distinguished road
Default Updated mirror part # for 05 replacement
Hi - I searched but only found outdated numbers.
I've had my mirrors replace twice under 3rd party warranty, only to find they've replaced them with the same part number mirror. I'm assuming this because they are completely black - no stainless insert. Oh yes - and because they crap out within 2 months.
Does someone know the latest part numbers of both updated mirrors that replace the 05 models or the TID that has it?
I really appreciate it.
thanks!
Dave
Old 12-16-2009, 02:11 AM
lvmyhmr lvmyhmr is offline
lvmyhmr is off the scale
Default Re: Updated mirror part # for 05 replacement
I have an '04 and had the original '03-'05 mirror design replaced several times and then the 3rd party warranty company replaced both mirrors with th '06 design. That ended the problem. I do not have the part number but I am sure the dealer can get it for you. Get them both replaced and have it behind you.
Old 12-16-2009, 06:52 AM
Rico001's Avatar
Rico001 Rico001 is offline
If the mirrors are replaced with 2006 mirrors will they plug into the 2003
wiring without modification?
I really need to do mine soon and if I find out the numbers I'll post them.
~Richard
Old 12-16-2009, 10:19 AM
Found it!
Subject: Info - New Outside Rearview Mirrors Available #06-08-64-007 - (02/09/2006)
Models: 2003-2005 HUMMER H2
New Outside Rear View Mirror Availability
The outside rearview mirrors have been redesigned for the 2006 HUMMER H2 and are a much improved design over those used on prior models. The new mirrors have a different appearance than the original equipment 2003-2005 mirrors. Should you have the need to replace a mirror on a 2003-2005 H2, you should replace both mirrors as the new mirrors are now all chrome. The new design mirrors are P/N 15835056 (left) and P/N 15835057 (right).
Most customers should be satisfied with the appearance of the new mirrors. The original style mirrors may still available for a limited amount of time. DO NOT order the original style mirrors unless the customer has an objection to the new style mirrors. Be sure to indicate that the new mirrors are both more robust and will help to update the look of the vehicle. Once supplies of the original style mirrors are exhausted, they will not be available.
Parts Information
Part Number
Description
15835056
OSRV Mirror - Left
15835057
OSRV Mirror - Right
***pn#15835056 changed to pn#25774400 retail $425.00
***pn#15835057 Changed to pn#25774401 retail $425.00
Subject: Adm Msg - 2003-2005 HUMMER H2 Outside Rearview Mirror Head Vibrates #VSS20040161 - (06/18/2004) Models: 2003-2005 HUMMER H2
Should a customer indicate that the outside rearview mirror head vibrates, this is a reminder to power fold the mirror prior to replacing it. If the mirror is manually folded, by a car wash attendant for instance, it will no longer be indexed to the detents. Power fold the mirror back and forth three times and this will resynchronize the mirror head to the detents.
A review of a number of mirrors returned to the Warranty Parts Center indicates that this would have corrected the condition. Also, take a moment to explain this procedure to the customer.
Old 12-16-2009, 05:29 PM
list price on the above numbers are $623.34 drsd / $425 pssd
gmpartsdirect.com
drsd $382.48
pssd $260.80
not sure if it's plug and play on the electrical side of it or if it comes with a new gasket that goes up against the truck.
Old 12-17-2009, 01:04 PM
jer1382 jer1382 is offline
jer1382 is on a distinguished road
I need to get mine replaced as well on my 04. Got into the truck today pushed the button to unfold the mirrors and my drivers side mirror stayed put. The passenger side swung open with no problem. Thing is I just got my truck back from the shop yesterday. They had replace the DVD screen on my passenger headrest. So I take it that these mirrors have this problem?
