Old 01-20-2010, 11:40 PM
hotstang46` hotstang46` is offline
hotstang46` is on a distinguished road
Default Tow 8k, Need Weight Dist Hitch?
I have an 08 H2, Do I need a weight distributing hitch to tow about 8k? I'm not near my vehicle to check a manual or look at the hitch but I seem to remember gm saying it had to, or maybe just advised it .. My truck does have the factory airbags btw.
thanks guys, I have to tow right when I get home so if I need this I need to order up if needed before I get home. And I guess if I do my only other concern is I don't really see a drop for one of those distributing hitches that would work. I'm stock height but on 38.5's right now.
Old 01-21-2010, 12:19 AM
twr's Avatar
twr twr is offline
Default Re: Tow 8k, Need Weight Dist Hitch?
Hi i would use mine at 8k. it will tow much better if your going far. Does your truck still have the rear tire mounted? If it does you will need to buy extensoin to clear the rear tire then a drop.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 01-21-2010, 04:58 AM
I do still have the the spare, in fact it matches the rest of the wheels and has a 22with a 38.5in bfg on it. But what is the need for an extension, I've towed my boats around with nothing but a drop hitch, no extension or anything.
Also, I'm having problems finding a company with a wd hitch that has a large enough drop shank, any idea who has one?
Old 01-21-2010, 11:56 AM
twr's Avatar
twr twr is offline
hi i have a 28 foot car trailer and i have to put a 5 inch extension i made in order the clear my spare tire, so i can put the trailer on the hitch, here a link to a kit just like mine. Their are cheaper kits out there. http://cgi.ebay.com/ebaymotors/Reese-10-000-LB-Weight-Distribution-Distributing-Hitch_W0QQcmdZViewItemQQhashZitem4cebb8062dQQitemZ 330372220461QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAc cessories
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 01-21-2010, 03:22 PM
tomp's Avatar
tomp tomp is offline
It is best to get a custom hitch shank made. You don't want to use an extension when towing anything heavier than a couple of bicycles.
Here is what my custom shank looks like: http://www.elcovaforums.com/forums/s...ighlight=hitch
Old 01-27-2010, 06:55 PM
Astroboy Astroboy is offline
Astroboy is on a distinguished road
Default Upgrade your hitch first.
With that much weight plus the leveraging effect of the extension, you're definitely pushing the envelop. Saying I wouldn't be confortable is an understatement.
FYI, you can find on the net, many instances of GM hitches failing and ripped off (many Suburbans and Tahoes).
The OEM hitch has a sticker that indicates the rating of 600 lb tongue weight without WD or 1000 lb tongue weight with WD.
The hitch hangs on the main ladder frame via clamps that is merely a few inches wide.
Solution -> Upgrade your hitch to class IV.
For a few hundred bucks, you can easily have a local hitch shop weld some additional cross members and reinforce the hitch. They can also legally rebadge and give it new rating.
I had this done, and now my new sticker says the hitch is good to tow up to 10,000 lb trailer and 1200 lb tongue weight without WD.
