Old 02-26-2010, 09:28 PM
vette94h@yahoo.com vette94h@yahoo.com is offline
vette94h@yahoo.com is on a distinguished road
Default removing H2 shifter
I need help removing the shifter to my H2. So I then can remove the dash pieces. So I can replace the LEDs. Of course there isn't a Haynes manual. Any help please.
Joshua
Old 02-26-2010, 10:57 PM
Hellz Hellz is offline
Default Re: removing H2 shifter
you will need a alan wrench to get the screw out.
if you were to put the veh in 1st gear, you should easily see where the screw is located.
once the screw is loosened up, the whole shifter pulls up to be removed.
Old 02-26-2010, 11:12 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I did a write up on installing BlueStar and it shows how to remove the shifter.
What dash lights are out?
Here is the link to the write up w/pictures:
http://www.elcovaforums.com/forums/s...ad.php?t=38848
Old 02-27-2010, 01:14 AM
Easy Ed Easy Ed is offline
Or, there was a question a while back wondering the same thing about the screw.
http://www.elcovaforums.com/forums/s...ad.php?t=38459
