03-23-2010, 09:58 PM
Synthetic Fluids
My 04 H2 has 60,000miles on it. I think I'm going to change out all the fluids to synthetic (unless not reccomended) Would you guys reccomend Royal Purple, Amsoil, or something different? Thanks!
03-23-2010, 10:09 PM
Re: Synthetic Fluids
i have a 03 H2
for engine i run royal purple
have not changed the diffs yet, but as long as they meet requirements, ill throw royal purple in those too
03-23-2010, 11:40 PM
Have always run Castrol Syntec with out any problems
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
03-24-2010, 01:53 AM
i'd recommend that also... the german made 0W-30 (which is near 40 viscosity when hot). you can get it at auto zone. make SURE it says "made in germany" on the back of the bottle (it's in small print). i've been using it in my LS engined Corvettes for years, great used oil analysis.
03-24-2010, 07:00 AM
this thread will go on and on  , but I only use RP oil in all my cars. That and redline are the two best oils you can buy. If not one of them I would use Mobil 1 it's the next best.
03-24-2010, 04:32 PM
Engine: Mobile 1 Syn and K&N oil filter
Everywhere Else: Royal Purple
I pick up a couple cases of mob 1 at Costco when they do thier money off coupon...makes it cheap!
03-25-2010, 08:58 AM
The truth 1st choice is Royal Purple in everything as I have since 2006. They make product for all applications I think. It is carried by NAPA and they are picky. Also Horse Power TV did an experiment with a late model camaro before they stopped making them and found a 8HP gain, mpg gain, and other things. I watched it and was stunned at all improvements.
I run SC high HP etc. and would run nothing else but, RP.
2nd choice would be Redline.
TAZ
03-27-2010, 01:57 AM
I use valvoline syn tech. I would say any synthetic is better than reguilar oil and fluids.
2006 H2 SUT Fusion Orange LE
12-23-2010, 11:08 PM
When running synthetic, how often do you change the oil?
12-24-2010, 04:35 AM
I'll usually go about 4K then change it. I'm old school and like to have fresh fluids. The Oil change indicator will usually say around 50-40% oil life left. I was always a 3k guy with regular oil.
12-27-2010, 08:42 PM
TAZ
Royal Purple IMO is the way to go.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
01-01-2011, 12:26 PM
Diffs, TC, Trans, and Engine all Amsoil.......actually the same in all 5 vehicles.
Is it fast?
01-04-2011, 03:39 AM
This my be wrong, but I change my oil the first of every year. This year I have 3,400 miles on a 2004. I use mobil 1 extended life. Have it washed, waxed and been checking prices on detailing the inside this year.
Still loving the drive,
Vern
Hybrid Mode
