05-05-2010, 11:29 PM
Can you get 37's or 38's on stocke LE wheels
W/O a lift? Also, with 37 or 38's do I need to re gear and adjust speedo? Whould I need a superchips programmer?
January 20, 2009, A Dark Day in American History. Tehee.
Sold. Miss u buddy.2006 SUV LE Demonguard and extras.
Looking
05-06-2010, 02:21 AM
Re: Can you get 37's or 38's on stocke LE wheels
You can certainly run 37's without a lift. I run a set of 37" KM2's for off roading without any problems. Change back to my OEM tires for street driving because the 37" tires raise the truck so that it won't fit in the garage.
05-06-2010, 02:41 AM
Yup just make sure any 37 you get is no wider than 12.5"
05-06-2010, 03:50 AM
yes to 37 and 38s on stock rims.
you will not need to regear, but it might be recommended to gain back any performance you will lose when you go to the bigger tires.
your speedo will by off when you go to the bigger tires. just firgure you will lose about 10%. speedo will say 60mph, but your only doing 54 mph.
what i did is bought a cheap predator programmer off Ebay for $99.
granted it was only for the 03 model, but thats what i have. ya im sure i could get better tunes if i bought a new predator tuner, but i cant justify the $350+ price tag on it.
also, be prepared to lose some MPG when you go to the big tires.
before on stock tires ( 35 inch) on 17 inch rims, i was getting almost 12 mpg
after i went to 20 inch rims with 37 inch tires, my mpg dropped to 9mpg... as in single digit 9.. and that was after alot of miles were put in. for the longest time, it read 8.something.
05-06-2010, 07:05 PM
I have 37" ProComp Mudders on the stock 17". Not sure if anything was done afterwards, the tires came with the truck, but my MPH shows only 2- actual speed at about 50mph.
No rubbing at all, not problems turning, just good help in the mud. Did get it stuck once this weekend. Will post a video in a minute.
'07 SUT w/LUX. 37" ProComp Xtreme Mud Terrains - Flowmaster 40 Series w/ dual tips - Delta 10X Light Bar - 6,000K's - E&G Fender Flares & Splash Shields - Guard & Some lights -
Coming Soon: Fabtech 6"
05-07-2010, 03:16 PM
I have to disagree with Hellz on the speedo tuning. You will actually be traveling faster than your speedo reads. reason beeing is that your truck calculates speed by measuring the RPM of the axle. It factors in the circumference of a factory 35"ish tire. So the computer thinks that every revolution should be
35x3.14= 109.9 Inches per revolution. But when you are running 37's you computer does no know that and while it counts revolutions against time to get mph the distance is actually 37x3.14=116.18 Inches Per revolution.
Or you can do it the easy way. Get a gps and set your cruise to 65 on your dash and watch your gps say your doing 69mph. lol
05-07-2010, 06:33 PM
HumminNBoatin' is correct. 68.7 mph to be exact.
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
05-07-2010, 09:13 PM
How do you fix the speedo to be correct? Thanks,
Looking
06-03-2010, 02:10 AM
I was actually thinking of getting larger tires as well for the stock 17in rims, however i do have a SUT with the air ride suspension, from my understanding there needs to be a mod done with the air sensors in the rear to make the 37's work
please correct me if im wrong
H2 LETS GO !!!
2006 WHITE H2 SUT
Hybrid Mode
