Old 11-02-2004, 01:55 PM
Brent Brent is offline
Brent is off the scale
Hello all.
I am a newbe at this but here goes and hope that someone out their might have the answers.
I ordered a H2 SUT and should receive it in the next two weeks acording to GM.
I want to put a 6inch lift and bigger tires. Is there someone out there that has done this and if so what lift kit do you recommend and what size of tires. I see they make a 37in and 40 inch to go with the 17 inch stock wheels.
Thanks for your help.
Brent
Hello all.
Brent
Hello all.
Brent
Old 11-03-2004, 11:48 PM
Thanks guys for all your help.
Can anyone tell me how many hours it takes to install the 4 inch Rancho lift kit.
No one around here has done it so it will give me an idea of the total costs onvolved.
Can anyone recommend a good web company to order this 4 inch lift.
Brent
Old 11-03-2004, 03:03 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Brent:
HI Tacyk
The answers to your questions
The truck will spend much more time on the freeway and pavement. I do not plan on driving everyday.
I do plan on taking truck off road but very little and not to crazy places.
even though you say it will be your second vehicle.. you will want to drive this thing as much as possible. ...At Least I do.
If you are not going to take this truck off-road much and it will be a pavement pounder, you may want to consider a 4" lift. It will handle better at the higher speeds. I know Rancho makes a 4" system for the H2 and you can still run 37's with the stock rim I believe. Do check with them or a 4wheel parts store.
I would say get your 37's on there and see if you like how it looks. If you want the truck to sit higher, than do your lift, shocks, sway bars, and all that other good stuff. A 4" with 37's looks SWEET! I have been to Moab Utah with my H2 three times since I got it and I'm VERY glad I did not have al ift on it. 37's, no lift, and still keeping that low center of gravity works for me.
Also keep in mind parking garage hieghts.
...my 2 cents.
Brent <HR></BLOCKQUOTE>
Old 11-04-2004, 01:40 AM
Hi all
Is the extra 50.00 per shock between the Rancho 5000 and 9000 worth it.
If I am mostly on pavment is the 5000 good enough?
Brent
Old 11-02-2004, 02:13 PM
Here is a 10" or so lift by 3rd coast suspension: http://www.bncoffroad.com/hummer/sut/
Old 11-03-2004, 01:01 AM
Sorry it was Timgco with the questions
How can you tell I am new at this.
Brent
Old 11-03-2004, 01:46 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Kacyk
Do the 35 Mud Grapplers rub at all?
Would the 37inch Bf all terrain KO rub on a stock H2?
I have TSL SSR's in 37's on mine with an aftermarket wheel that is the same backspacing as an oem(as show in the picture). They rub just as much as the stock 35's do. If you notice when you 1st get your H2, you will notice a slight rubbing on the inner fenderwell, and that's about as bad as it will get with 37's. I have not had any issues with the 37's as far as clearance of fenders. As a matter of fact, you actually pick up an inch or so when you go to the 37's which is nice when wheeling. There are lots of folks that have been happy with 37's on the stock wheel, and to my knowledge there have been very few issues with this upgrade!
Good luck, and congrats on your new Baby!
Ric-H2
www.meatspin.com
Old 11-24-2004, 06:53 AM
Andre Andre is offline
Andre is off the scale
RIC-H2
I love that color, don't know why they droped it. Nice truck.
Old 11-03-2004, 03:08 AM
Here's a pic of a member's ride with a 4" kit and 37's.
Old 11-04-2004, 12:37 AM
It should take about 6 to 8 hours for a mechanic who knows what he/ she is doing. However, I wouldn't just take this to anybody to do. What state are you in? 4Wheel Parts stores are everywhere and most do excellent work. Ask for a refference from your installer on a tahoe or 1500 P/U. And above all, make sure your front end alignment is done properly when you put the bigger tires on.
Old 11-02-2004, 05:04 PM
Two questions:
1) Do you plan on driving the truck every day and at freeway speeds often?
2) Do you plan on taking this truck off-road?
If you just like the look of the bigger tires, Many people here run 37's on the stock rims and have only slight rubbing. Anything larger on stock rims will cause issues.
Old 11-03-2004, 03:23 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
The 35's rub slightly when making hard turns (but so did the OEM set). I've seen 37's on stock wheels and they look great.
BTW, I returned the Mud Grapplers for Terra Grapplers because the mud tires were just too noisy for us as a daily driver.
2003 Yellow H2 LUX (Sold)
Old 11-02-2004, 06:54 PM
kacyk's Avatar
You can still get a good aggressive look without a lift or even 37's. These are 35 Mud Grapplers on a stock suspension. I decided not to lift the beast due to where we live and underground parking issues.
I'd drive it for a couple of weeks then decide. But if this is a second car for you and you just want to go wheeling, then have at it.
Old 11-02-2004, 02:50 PM
Thanks Paragon
Looks great but I think I will stay with a 5- 6 inch lift.
My girlfriend would never be able to get into this rig.
Brent
Old 11-02-2004, 03:26 PM
kacyk's Avatar
Hey Brent,
It's always an adventure helping beautiful women up the trucks!
Old 11-21-2004, 06:21 PM
H2Beast H2Beast is offline
H2Beast is off the scale
Hello there..
Maybe late reply, cck my site and see my H2 with Rancho 4" lift kit and Goodyear MTR 40 on stock rims. Mind that lifting the car will require to change the rims as the backspacing will need to be max 4.5". I used performance wheel spacer kit. Slight rubbing but everything looks and perform just great. Remeber that ur upper control arms will need some mods. PM if u need further help
Hummer H2 2004, Jeep Wrangler Rubicon 2004, Corvette C5 2004. All modified..Check my website for more info.
Old 11-04-2004, 01:32 AM
Thanks Again for your info.
I am from BC, Canada eh.
We do have a couple of 4X4 shops here but none have but a lift in a hummer from what I know.
I will look at this Trailduty.com and go from there.
Brent
Old 11-04-2004, 12:13 AM
SOCRATES SOCRATES is offline
SOCRATES is off the scale
Brent,
The install was done by the dealership -- it was their first. They had it for 4 days, but only because it was their first Hummer lift, and they wanted to take their time. I was told to stay away from the SkyJacker lift, but the 6'' Fabtech and 4'' Rancho kits both seemed to be excellent.
I can wholeheartedly recommend Trailduty.com. They gave me an excellent deal and the service was fantastic.
Cheers,
-Justyn
05\' Black SUT
