Old 08-23-2010, 02:57 AM
H2005's Avatar
H2005 H2005 is offline
H2005 is an unknown quantity at this point
Default Amatuer radio in a H2
Has anyone installed an Amatuer radio in a H2 yet? If so any photos?
Old 08-23-2010, 03:10 PM
mightyepp's Avatar
mightyepp mightyepp is offline
mightyepp is on a distinguished road
Default Re: Amatuer radio in a H2
I have been looking at this too. I saw some pics online. Most people just replaced the OnStar system. It is easier to hook up that way since you use the wires already there.
2003 Hummer H2
Old 08-24-2010, 11:19 PM
H2005's Avatar
Does anyone know where a good place is to run power though the firewall and also where to route the antenna coax?
Old 08-25-2010, 01:54 AM
guruerror's Avatar
There's a large rubber grommet up under the dash...I can't remember what OEM part goes through it, but that's what I used to run several things through the firewall. I'll take a picture of it in a bit and post it.
It's hard to miss...if I recall...it's up under the dash almost directly inline with the parking brake...it comes out in the engine compartment below and behind the fuse box.
Get and ice pick and some duct tape...tape your wires to the ice pick and poke it through.
Works like a charm.
CNTRY
DTOM
Old 08-25-2010, 02:27 AM
guruerror's Avatar
Assuming that your talking about a CB...here's what I did:
  1. Removed the OnStar unit and mounted the control unit for a Cobra 75 WX in the dash (hidden)
  2. Mounted the handset for the Cobra 75 WX on the side of the console
  3. Used a piece of angle iron to construct an antenna bracket on the rear tire carrier
  4. Replaced the FM antenna vent with a 2003 vent (no antenna mount)
  5. Routed the FM and CB attenna cable to the rear of the truck (using one of the FireStiks for FM) and exited throught the power grommet used for the license plate light
  6. Mounted two FireStik antennas on the angle iron
  7. Routed power (for CB and other peripherals) throught the large grommet in the firewall directly behind the parking brake
Hope this helps.
CNTRY
DTOM
Old 09-28-2010, 03:45 PM
H2005's Avatar
guruerror,
A photo would help also thanks for everyones help.
