Old 10-28-2010, 12:10 AM
chaplaintroy chaplaintroy is offline
chaplaintroy is on a distinguished road
Default air compressor
HELP I am a chaplain not much mechanic skills I have a 03 H2 Hummer with the air suspention, the compressor has got where it continously runs after the engine is shut off and has killed my battery can you tell me how to unplug the compressor until I can get everything fixed
Old 10-28-2010, 12:48 AM
Default Re: air compressor
I don't have air suspension but if I remember correctly, the compressor sits right in front of the rear bumper.
If you look at it,you should be able see how to disconnect the power. If not, I'd imagine there are only 2 wires going to it. You could just cut one and wrap it for now.
If you do that, make sure you don't cut it so close to an end that you can splice it up again.
Mark
PS. I'm moving this thread to technical.
Old 10-28-2010, 01:15 AM
Default Re: Air compressor
Mark thank you for the info, as I looked at the compressor there was 2 wiring connectors that was plugged into the back side of the compressor they look like the connectors for a trailor not sure which to try to unplug also would it be very difficult to do away with the air system altogether and have regular suspension again thanks
Old 10-28-2010, 01:39 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Sounds like the compressor relay is stuck on. It is located below the brake master cylinder just above the framerail.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 10-28-2010, 01:47 AM
could you tell me what I should do to fix this thankx
Old 10-28-2010, 02:01 AM
HUMTECH's Avatar
If it is stuck, just replace the relay. Common problem in the early models due to being so close to the exhaust manifold and getting hot. Its a safe bet that its stuck, just unplug it and go to the dealer with the old one and order a new one
1998 Chev Z71
