Go Back   Hummer Forums by Elcova > Hummer H1 Discussion Forums > Photos of YOUR H1
Old 02-23-2004, 03:22 PM
Had PJ's installed last week. This one's on the way to be balanced.
Old 03-15-2004, 09:47 PM
Hummer Man is off the scale
P Jones' are great tires!
Old 03-15-2004, 11:31 PM
alecs wife alecs wife is offline
alecs wife is off the scale
I could not hep notice that it is a "D" rated tire. I think that for the type of vehicle we are placing them on they would have to be "E" rated. Why would a Hummer owner put a "D" rated tire on their truck?
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
Old 03-14-2004, 11:51 PM
Who makes these tires?
Will you post a web address?
Old 03-16-2004, 01:59 AM
ssgharkness020147's Avatar
R2,
The larger PJ's are E rated tires. The exeption is the 37x12.5x17. I dont know why that has a D rating, my truck has 16.5 Cepeks on it and the Dirt Grips on my truck have an E rating.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 03-15-2004, 02:57 AM
R2,
The tires are made by Parnelli Jones. Here is the link to the adress that I have to look at and or purchase them. http://www.ntwonline.com/acb/showdet...=1211&CATID=10
-007=
Old 03-02-2004, 11:05 AM
JSA_3 JSA_3 is offline
JSA_3 is off the scale
Great info thanks Carey. Had no idea on mounting and balancing costs. (I do have the 17" two piece wheel though)
My biggest concerns were/are Not having a spare with 16k on my tires that are starting to show signs of wear, and limited availability of the MTR with no production date set.
After your's and Buck's take on the PJ I may sell 3, keep 1 as a spare. Then when the time comes find a set of PJ's.
Thanks,
John
'02 HMCO
\'02 HMCO
Old 02-23-2004, 03:36 PM
Looks a little naked
Old 02-23-2004, 03:30 PM
I bent my crossmember a tad, damn rocks.
Old 02-24-2004, 11:03 AM
Me either
John
'02 HMCO
\'02 HMCO
Old 03-01-2004, 07:47 PM
John,
Yep, used them Saturday in Big Bear in about 2' of snow and mud. They were awesome. They impressed me the most when I towed an H2 UP a slope, 2' of snow, a little ice all the way from the drift he was stuck in to up and over the hill that he slid down earlier. I seriously couldn't believe the grip these tires had in the snow.
For the record: The h2 I pulled had changed out his tires to more of a street type setup that just could not make it up this hill and eventually got really stuck at the bottom in a drift.
Old 02-23-2004, 04:05 PM
Interesting idea, thanks Joe.
Old 02-24-2004, 10:52 AM
We kept them, no controversy for me yet.
Jason
Old 03-01-2004, 07:32 PM
Hey Buck,
Any trail report on the PJ's yet?
I chickened out and had my tire dealer locate 4 MTR's, for me to put back in reserve. (he found them one at a time, scattered all over the U.S.)
John
'02 HMCO
\'02 HMCO
Old 03-02-2004, 05:06 AM
At the risk of repeating my self. PJ's are the way to go. The PJ's drive very well on road, lots better then swampers, and are great off road (hopefully someday I'll get to find out first hand). If you unloaded your MTR's which as you know are in very short supply you could probably almost cover the cost of PJ's. JSA_3 if you want the name of the place that I found PJ's for pretty cheap (282.00 per tire) email me of the list and I'll send you the link. As far as runflats are concerned; I have the 16.5 Cepek rims, with the dirt grips, and no run flats. Some people have problems with, them some dont. My truck did not come with runflats, and I cant say I wish that it had. Aside from the usual problems with runflats, do you guys know how much more it costs to have tires put on a truck with runflats? I got my tire mounted and balanced to about 350.00 as oposed to the 800.00 that it would have cost with the runflats. Being that I have one pices wheels I is a lot harder to try and mount the runflats and tires, Buckeye, has two piece wheels which if I had to guess makes the tire change cost a lot less.
Carey Harkness
1998 HMCO
-007=
Old 02-23-2004, 03:25 PM
Damn rocks in SoCal scratched my wittle wims.
Old 02-24-2004, 10:46 AM
Jason,
Great looking tires! Did you do anything with the runflats? There seems to be little controversy as to keep or not to keep.
Thanks,
John
'02 HMCO
\'02 HMCO
Old 02-23-2004, 03:28 PM
A couple of Hummers in the shop.
Old 03-06-2004, 09:42 PM
Joe Joe is offline
Joe is off the scale
Actually working with the 2pc wheels is more costly. Eveything has to be done by hand, no tire machine to mount up the tires. The runflats are a BITCH to work with. Forget removing them unless you have a runflat compressor. Some folks suggest you can compress the runflat with a ratched strap but I don't believe it. I tried one day and I mean one day (hours) and could not make it happen to get them out... Beadlocks are the way to go if you can get them. They are a simple rubber ring that is 1000% easier to work with and locks the bead internally.
I just spent the day setting up a 2nd set of 2pc steel wheels with my GSA/Runflats today. Plan on running these day to day on the street (and in to the ground) and use the PJ's for off-roading.
Neither set is balanced but I am using Centramatic balancers. The work ok on the PJ's, pretty much rocks to hell after 55mph. The GSA's run perfect up to 75/80 so far.
2001 H1 Opentop
Former 03 H2 Adventure Series
Homepage:
http://www.hummerh1.net
2001 H1 Opentop
2003 H2
Homepage:
