11-19-2010, 10:38 PM
How to change F & R Differential fluids
Hello Everyone Thank You in advance for all replies given!!
I would like to save on money on the changing the rear and front differntials fluids on my 2003 Hummer H2 80,000 miles young. Can anyone point in the right direction on how to start this project which hopefully includes what type of fluid and how much I need, what is involved with changing out the fluids (does it consist of a full flush of the fluid?). Any other concerns please note them for me. Thank you again!
11-20-2010, 04:31 AM
Re: How to change F & R Differential fluids
Tools you will need:
3/8 socket wrench
something to drain the oil in to
5 quarts of 75/90 gear oil
Optional: about 1 ft of 1/2 tubing to make it easier to put in new oil.
on the front diff, use the socket wrench to remove the top fill plug
use the socket wrench to remove lower drain plug
drain in to whatever bucket.
wipe off drain plug ( its magnetized, and will have alot of shavings on it)
put drain plug back in
from diff will take 1.5 quarts ( plus or minus some) fill it till it starts to come out of the fill plug hole.
put fill plug back in and done with the front diff.
rear:
should be a rubber gromet for the fill plug.
pop it off and place your oil pan down.
remove drain plug with socket wrench.
drain oil
replace drain plug, and fill till it starts to come out of the fill plug hole.
maybe about 3 quarts give or take some.
this whole job can easily be done within 15 minutes.
once you have done it, you will laugh at the fact that oil change shops charge $75 to $150 to do that simple job.
11-20-2010, 04:37 PM
does the gaskets need to be changed on the diff's or do you use rv stuff to spread around the gasket area for a good seal? Also can i do it on a lift or does it have to be on a slight incline/decline for the oil to drain all the way out? Thanx in advance
11-20-2010, 06:27 PM
since you are only going to remove the fill and drain plugs...I Hope  ....there is no need to seal the gaskets since you won't be splitting the case
2004 Black H2
11-20-2010, 06:36 PM
Sorry I had been confused from seeing you tube how to's on differential's where there where splitting the case open to have the oil drain out.
11-20-2010, 10:23 PM
i had to replace a washer on the front diff plug, it had a slight drip.
once i had the washer replace all was fine.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
11-21-2010, 03:31 AM
I know the dealership wants $125.00 for each. I was thinking what the heck does it take to this myself and you just answered it. Thank You
11-22-2010, 12:59 AM
Please do not take offense to this, but if you were not aware of how to drain and fill a differential, I would use caution before you start to dive in on self repairs. You will REALLY want to be sure that you verify ANY advise you get on working on your H2.... Use the wrong fluid, not fill it up all the way, forget to tighten something and you will REALLY regret not spending the extra cash to have a shop do it.
Now, I am of the opinion that if you want it done right you need to do it yourself and certainly do not want to scare you out of changing your diff fluid as it is really straight forward... I would suggest getting one of the H2 service manuals and ask A LOT of questions
11-22-2010, 08:33 PM
Great write up by Hellz..Follow his instructions and you'll be fine. It's a simple job, paying a dealership is ridiculous. I went with Royal Purple and couldn't be happier.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
11-22-2010, 08:48 PM
the hardest part about changing diff fluids is finding out what gear lube to buy. really, thats the hardest part. i did have to search for it a little on the web, but once i found it and bought it, my wife could have changed the fluids.
there is very very little to mess up with changing the diffs. 2 screw on plugs in the front, and 1 screw on and rubber grommet for the rear.
iirc, i think i used moble 1 with limited slip additive. you will need it, but even if the diff didnt require it, the additive will not hurt being in there.
you could go the highend route and buy royal purple.. i really wanted to, but i didnt want to spend $18.99 a bottle.
again, the hardest part is finding which fluid you use.. otherwise its simple, and no way worth spending the money to have a quick lube place do it for you.
i agree there are alot of thigns that people shouldnt tackle if they arent familiar with changing fluids, but changing fluids isnt one of those if there is a little research done before hand.
hell, most of the things i have done to my H2 i have never done before, and researched the hell out of before i do it..
11-23-2010, 02:02 AM
So is it a good idea to do Transmission as well at same time if you?re doing Differentials and T-Case? I am in that position where with 38,000 miles i want to get Fluids switched out to Schaeffer's in my TC and Diffs but was considering doing tranny too. I know the Dealer wants 550 for Diffs, TC, Tranny, but I would only do it if they let me use the fluids i want like Schaeffer. I am wondering if i am better off doing TC/Diffs myself and having a tranny shop do the flush? Is it best to flush or should i just drain out like the 5 quarts and just replace?
Richard
11-20-2010, 05:38 PM
Can we add the Transfer case to this? Procedure and fuild type/capacity.
01-24-2011, 11:30 PM
Finally changed both the Front and Rear diff. fluids with the Mobile1 you guys recommended (Royal purple sorry just too expensive for me at this time). Project was easy. Thank You all for the help. Used 1.5 quarts in the front and under 4 in the rear. Both of them i filled until it came out the fill hole alot.
01-25-2011, 12:09 AM
ya RP is some serious $$$
1 pint goes for $18.99 here at most part stores.
now that you did the diffs, the transfer case is just as simple.
just make sure you get the correct fluid.
06-16-2012, 11:58 PM
FYI I just did the diff fluid changes in my 06 H2 and the front drain/refill is a 13mm/15mm.
There is no rubber fill plug on the rear diff. Both drain and fill are 3/8th ratchet type, same as transfer case.
Thought this might help somebody!
Oh, and also, my rear diff went through more than 3 qts !
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
06-17-2012, 04:17 AM
well i have about 1k on my new gears, and was going to change both diffs today while i was working on fixing a squeak on my new brakes....
last weekend i put on new EBC brakes, but didnt have lube for the pads, so i slapped em on anyways... fast forward to day...
the Caliper wouldnt come off on the driver side... so unbolted the brake line to relieve pressure.. it worked out better in the end because i also painted the caliper and bracker while it was off..
since i already had to bleed the brakes anyways, i did the same thing on the pass side... well after painting, and putting the bracket in.. it slipped and landed in the bucket underneath the rotor which splashed brake fluid up in my eye!
well after flushing my eyes for a good while.. decided to call it for the night..
but while i was out.. picked up 6 bottles of RP gear oil @ $21.99 each.. OUCH!
so, will be finising up the brakes and doing the diffs tomorrow..
06-17-2012, 06:37 PM
That sucks about your eye. I wear sunglasses almost all the time but under the car I didn't , so i could see better. When I was younger I'd do most anything without eye protection. Now that I'm getting older.... For some reason I think about those things.
I was told by a knowledgeable guy, and followed it up with some reading, that redline is far superior gear oil than most. Just like royal purple is for motor oil.
I did all my stuff in redline and it was cheaper. I couldnt believe how much that RP was.
I wish I would have gotten the high temp DT4 for the transfer case, but I just grabbed the regular.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Hybrid Mode
