Old 12-05-2010, 07:11 AM
Default So I've driven the diesel conversion for about a month... final impressions.
As ya'll know, I got the H2 back from the diesel conversion about a month ago.
I've had a couple of bugs that needed to be ironed out.... mostly minor but nonetheless, stuff that I needed to do to make the truck as factory as possible.
As of now, the truck is completely in working order.... no lights, no CEL's, absolutely nothing.
With the tuner that I'm using right now (I've been through 4 of them) I'm only averaging about 14 mpg in the city and 17'ish on the highway.
If I use a different tuner, I can increase that by at least 2-3 mpg. (Diablo seems to work the best all around which is what I'll be switching back to shortly)
Anyway, I realize for those of you that already have diesels, I don't need to tell you how happy I am with the pulling power, the ability to drive up hills with a trailer and the general performance of a diesel.
The conversion was well worth the money and if any of you are planning on keeping your H2 indefinitely, it's a worthwhile investment.
Just thought I'd give ya'll an update.
Mark
Old 12-05-2010, 04:37 PM
twr's Avatar
twr twr is offline
Default Re: So I've driven the diesel conversion for about a month... final impressions.
Hi Mark, you have tried 4 programmers! i thought i was bad with 2 programmers. Anyway glad your Dmax Conv works so well.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 12-05-2010, 05:16 PM
And more....
I started off with the PPE HOT tuner.... liked it, didn't give me the gas mileage I was looking for. Was able to program gear ratio and tire size.
Sold it to a friend for 400 bucks. (800+ unit) and bought a Diablo T1000. Wasn't overly happy with the quality (seemed cheap plasticy case) but worked well, gave me over 20mpg on the highway. Was not able to program gear ratio or tire size, had my ABS and BRAKE light come on.
Bought an Edge CTV programmer. Basically, in between the first two but the light came on with it also.
Went about bought a economy PPE tuner (only 3 levels cause I was going to trade it to my buddy I sold the HOT unit to since his truck was stock and could only use the first 3 levels anyways)
When I went to reinstall the PPE tuner (economy) I realized I had put the unit "back to stock" meaning it had a stock program, I did not uninstall the economy tuner.
Got it, traded it back for the HOT unit and my brake and aBS light was still on.
Soooo, now, I had to spend another couple of hundred bucks to have the economy tuner reflashed so I could send it back and give it to my buddy.
Turns out, the EBCM went bad in between the first PPE and the Diablo. (who knew?)
I replaced it and while I was doing so, I reprogrammed the ECM to reflect the VIN number from the donor truck.
And now that it's all said and done and I have everything working, I'm going to go back and buy the Trinity again.
I've got more money in shipping and reprogramming than I do in any tuner.
Mark
Old 12-21-2010, 11:32 AM
kalantar kalantar is offline
kalantar is off the scale
Thanks for sharing OC, you have any vids?
edit ( found my response in another thread)...
Old 12-23-2010, 06:52 PM
o2man98 o2man98 is offline
o2man98 is on a distinguished road
Why not go with EFILive?
2007 H2 SUV All-Terrain Blue - His
2008 H3 Alpha Graphite Metallic - Hers
Old 12-23-2010, 11:48 PM
EFILive is an awesome setup.... however, I just want plug and play. Too many bells and whistles.
In fact, I just got rid of my PPE (AGAIN) and bought another Diablo. The PPE was 10 levels and the Diablo is only 3.
I'm not racing it, I just want to click on a setting and drive the damn thing and when I tow, have the ability to change tunes. Sometimes, too much is just that.... too much.
Also, the diablo gives me the best gas mileage so far. I'm averaging over 19 mpg in the city... at least 6 more than any of the others.
Mark
Old 01-19-2011, 02:58 AM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
Hey Orange, are you still able to lock the rear diff and mid diff through the dash, I assume they put the the regular GMT 800 switch selector into it.
Old 01-19-2011, 03:25 AM
Yup, it's like a normal 4WD from GM.
Mark
