Old 12-21-2010, 01:25 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default RockStar?
OK I am ready to buy some RockStars.
I have a front leveling kit installed with Cognito UCA (if it matters), I dont think I got much of lift from it.
Anyway my question is what wheel is best for the H2 considering backspacing?
I can go with either of the 20" wheels or the 18" wheel. I plan to have either 37X12.5's or 37X13.5.
Offset: 0
Back Spacing 5
or
Offset: 10
Back Spacing 5.14
or
Offset: -24
Back Spacing 4.56
Currently I have a 20X9" wheel with 5.75BS and +18mm offset with tires measuring 35.4 X 12.8, they do rub at full lock and miss the inside fender well by about an inch.
Really hope some wheel/tire SME can help me out, as I am ready to buy before the wife spends the money.
Old 12-21-2010, 02:42 PM
Hellz Hellz is offline
Default Re: RockStar?
IIRC,
Rim Diameter: 20 in
Rim Width: 10 in
Offset: -24 millimeters
Backspace: 4.56 in
personally, i would go with 22 inch rims or maybe 24's if you dont plan on doing any serious off roading.
i have 20 inch rockstar rims with 37 inch tires.
between the size of the actual tire, and the size of the H2, 20's seem small.
i also have the cognito UCA, so we are runnign the same setup mostly.
if you want pics, let me know
Old 12-21-2010, 03:15 PM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
I stuck with the 18x9 because I don't like the tires hanging out. It looks a little small sometimes but I want to get in the garage and the car wash Mine is stock height and I have noticed that the Duratrac's really roar at 80 on the highway.
Old 12-21-2010, 04:28 PM
SmokeyJoe's Avatar
Are your tires 37" or 35's? With the 18" rim does your tire rub or hit anywhere?
Old 12-21-2010, 04:39 PM
tsdrummerboy's Avatar
tsdrummerboy tsdrummerboy is offline
tsdrummerboy is on a distinguished road
what`s the average price of rock stars?
Old 12-21-2010, 05:26 PM
i need some new pics. these are the same pics i have floating around here.
tires are BFG KM2 mud tires
37x12.5
no trail running or off roading to speak of, other than just messing around in open areas.
tires are good on wet conditions and great on dry conditions.
on snow... if the snow is compacted, they suck. they will dig in and eventually get traction.
fresh snow, they are good.
ice they suck
i blacked out the chrome star.
i never did the mod to bring the center plastic hub closer to the rim.
i have the air ride system, but since the tires were only 12.5 wide, i did not need to do the air sensor mod.
i do get some slight rubbing on full turns, but it is very slight.
i do have the T bars cranked up some to avoid inner wheel well rub.
on the straight wheel pic, you can see where i trimmed down the inner wheel well plastic. (Pic #1)
also, with 37 inch tires, i had to remove my rockguard rails as there would have been direct contact at even a slight turn.
i dont know if anyone else experienced this issue, but i hated my sidesteps and rockguard anyways.
so far, i have had the tires mounted for a little over a year
prolly about 20k miles on them, and there is a ton of meat left on them.
in the last pic, you can see where the rubber between the lugs are now flush with the treads. i would say there is a good 1/2 inch of meat on the treads right now. so milage wise, they are holding up pretty well.
milage is about 9.5 mpg on the DIC with the 37 inch tires.
prior with stock tires, i was at 11 mpg ish.
4.10 gears (stock)
PIA 510 DRL's
NFAB sidesteps
diablo tuner
K&N CAI
Fabtech HD tierods
Cognito Steering dampner
Cognito UCA
Cognito end links
Bilstein shocks
Timke Hubs
Moog lower ball joints
Moog Pitman, Idler arm and pivoter arm
new half shafts
Old 12-21-2010, 04:27 PM
SmokeyJoe's Avatar
I would like to see some photos if you can. Also which tire are you running? Experience any issues on or off road?
Thanx
Originally Posted by Hellz
IIRC,
Rim Diameter: 20 in
Rim Width: 10 in
Backspace: 4.56 in
