Old 03-11-2011, 07:38 AM
Default LED Lighting w/ Lower Grille
Sneak Peek of the Custom Rigid Light Bar in the lower grille.
This will be a kit you can purchase for the H2's for 03-07. I have not looked at the deisgn behind the lower grille on the 08-09 yet. But I know the lower grille is different.
I got the spacers designed/ made today, templates made for the 2 holes that need to be drilled, and mounted it up. I have to do a full install guide with pics yet.
* Rigid Ind LED bar was cut to the specification I requested.
* It fits like a glove with enough room around it for through airflow/proper cooling, light output without shadowing.
* Roughly a one hour install is what I estimate once the kit is completed.
* You do have to dremel out the lower grille, but the lines are so easy to do and that plastic gets cut like a hot knife through butter.
* Hinges with the hood also. So you don't have to remove that bumper.
* Sits back far enough you won;t smack it on stuff either.
Old 03-11-2011, 07:40 AM
Default Re: LED Lower Grille
Also got the 50" mounted up for it's test fit.
I will do a custom rack so the bar sits back in there. I don't mind it out front, but I do prefer the integrated look. I'll have to get more pics in the daylight on how it mounts up and looks from the side profile. It's a monster.
I have to do the the wiring next week though. I'm excited to get these lit up. ..my neighbors won;t be though.
This pic is a bad angle. I have the bar sitting 1/4" lower than the top bar of the GOBI.
Old 03-11-2011, 11:28 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Re: LED Lighting w/ Lower Grille
Both bars look great.
What is the current draw on those two light array?
Old 03-11-2011, 01:33 PM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
Timgco
Looks absolutely great. Those are some really nice looking lights.
Old 03-11-2011, 04:42 PM
mightyepp's Avatar
mightyepp mightyepp is offline
mightyepp is on a distinguished road
Looks awesome in the grille. Can't wait to see that 50" light bar lit up either.
2003 Hummer H2
Old 03-11-2011, 05:00 PM
Intercooled's Avatar
Intercooled is off the scale
Looks pretty cool. How will the lower LED be switched and wired?
2006 H2 SUT Fusion Orange LE
Old 03-11-2011, 06:05 PM
Draw is very low on the lower grille. 5.2 amps.
The 50" bar up top is 14.4 amps.
