Old 04-30-2011, 11:16 PM
draconianruler draconianruler is offline
draconianruler is on a distinguished road
Default AC not working
My AC is not blowing cold air. I checked the fuses and they are fine. How can I tell if the compressor is being engaged or not? The belt moves around the compressor pulley but it doesn't seem anything else on the compressor is moving. Is that normal or is my compressor bad?
Old 04-30-2011, 11:35 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: AC not working
You can see the end of the compressor spin if it is working . try haveing a friend turn on the ac while you watch the compressor. you will see and hear it engage if it works . If it won't go on it could be low on freon ,or the high preasure switch or connection to the high preasure switch could be bad . Or your ac head unit in the dash took a dump . Any ac shop can tell you whats wrong free ,fixing it will cost though .Good luck and be glad your not in Phoenix with out AC in the summer .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-01-2011, 04:28 AM
I just bought some freon and I'll try charging it. Hopefully that is the problem.
Old 05-02-2011, 04:54 AM
Does the Hummer use a special AC fill adaptor? When I connect the Freon can to the fill nozzel (smaller one), I get no pressure. If I squeeze the trigger to add nothing comes out. The conncection seems to be connected perfect. I checked by connecting and adding a little on my vette and it works. Am I doing something wrong?
Old 05-07-2011, 01:13 AM
IRA51's Avatar
NO. THERE IS A HIGH SIDE AND A LOW SIDE PORT. FYI if you over charge the system you drive the head preasure up and blow the seals in the compressor ,be carefull . Have a good AC tec check the system for you . An over charged system will not get as cold as a properly charged system.
you have.
-- Thomas Jefferson
Old 05-13-2011, 07:08 AM
So it turns out you need a special adaptor to connect the pressure gauge/hose to the new refridgerant bottle. Apparently if you have a older pressure gauge/hose it will not work with the newer bottles (It might just be a CA thing).
The good news is that my compressor and AC does work when the refridgerant is full. The bad news is that I have a bad leak somewhere. After a day its all empty.
I bought some more refridgerant with the UV dye and looked for the leak but can't find it. You'd think it would be easy to find with such a bad leak. The only place I didn't check was the evaporator area inside the dash. Anyone ever pull out the dash to get to the evaporator core?
