Old 05-06-2011, 03:19 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default 3.5" Backspace Wheel
I am going crazy trying to get a wheel I like in the size I need. The wheels I ordered from M/T are now delayed again until July.
So I found some I like the ATX wheel but it has a 3.5" back space. Has anybody tried a wheel with such a low back space. I will be running a 37X12.5 tire and have a leveling kit on the Hummer.
Any help would be appreciated.
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 05-07-2011, 04:48 AM
slippy slippy is offline
slippy is on a distinguished road
Default Re: 3.5" Backspace Wheel
your tires will stick out 1.5 inches more than stock which would look goofy IMO with a 12.5 wide tire.
also you will be eating up hubs.
if you want a wide stance get a 4.0 backspacing and a 13.5 wide tire.
Old 05-07-2011, 10:42 PM
ROUSHDEMON's Avatar
agreed.
You want at least 13.5 with 37" tires. with wide offset I'd recommend getting lifetime warranty replacement hubs and you'll be fine. if you can't find the right offset wheel you could always get some 20 or 30mm spacers for all 4 wheels.
2003 Black H2:
2006 Blue H2:
Old 05-09-2011, 02:00 PM
SmokeyJoe's Avatar
OK here I go again.
Its a real pain living over here in Germany sometimes.
So this is the 3rd wheel I have tried to order.
I just placed an order for the "Black Rhino Imperial" with a 5.5 BS. Figure its the same as the OEM so I should be good to go. If I need to I can always add a spacer.
Discover STT's sitting in the garage 37X12.5 since January. At least I could get them on post.
Old 05-10-2011, 05:56 AM
stock backspacing is 5.0, so those wheels will stick in half an inch. if it doesnt work out just add .5inch or 1inch spacers and youll be fine.
Old 05-10-2011, 06:39 PM
Here's the correct wheel specs on the stock 17" wheel:
Offset: 18mm (0.709") positive
Backspace: 5.563"
So using a 3.5" bs wheel is not the right setup. 35's will hit imo.
4.75bs with 37's hit the back of the front wheel well...until you turn the tbars up a little.
