06-02-2011, 01:16 AM
Need help on HVAC schematics
Can someone with a technical manual post a picture of where the recirculate actuator is located in the dash and a part number.
My recirculate feature isn't working...
If anyone has other ideas, do tell
06-02-2011, 02:10 AM
Re: Need help on HVAC schematics
<A href="#ss1-1827662">Condition/Concern:
Owners may comment on poor a/c performance or that the recirculation mode is inoperative. When checking DTCs, a B0229 will be set in the HVAC control module. When this concern happens, the recirculation door is defaulted to the fresh air mode and the recirculation door counts will be less than 5.
New HVAC control head calibrations have been released to correct all over travel/out of range DTCs (B0229, B0414, B0424, or B3770).
<A href="#ss2-1827662">Recommendation/Instructions:
To correct this concern, reprogram the HVAC control head with an updated calibrations. This new service calibration was released with TIS satellite data update version 5.0 available May 1, 2006. As always, make sure your Tech 2? is updated with the latest software version.
Important: After reprogramming the HVAC control head, shut the ignition key off for 1 minute or the calibrations will not take.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
1998 Chev Z71
2007 Chev Trailblazer SS
06-02-2011, 02:32 AM
What he said  Thanks HUMTECH for the info, hope that will take care of their problem cause replacing it looks to be a pain.
And.... if you want to know where it is at, open your glove box till it folds down/drops down till you can see behind it, then these pics will tell ya what you need to be looking at to get at it.
GM Parts Direct shows a item #15 but it give a price for a left and a price for a right, problem is I would say it is the right one (if you need one) and it is the more expensive one, $137.05.
Good Luck, Ed
06-02-2011, 02:37 AM
Typically its a 1 hour charge for a module reflash with no guarentee that will fix it. Like easyed said, bit of a pain to change it out. Easiest way i have found is to remove the upper dash panel and you can access it from there. Not a terrible job just will take some time if you dont have much experience with gm trim panels.
1998 Chev Z71
06-02-2011, 02:39 AM
Oh and any gm dealer can do the reflash, we all have the same access to programming as its all web based
1998 Chev Z71
06-02-2011, 02:42 AM
What year is your Hummer?
1998 Chev Z71
06-02-2011, 02:45 AM
I don't trust the local chevy dealer, they give me bs everytime I go by, I'll just go to the HUMMER Dealership...
I have changed the actuator for the rear Hvac in a Tahoe... but you only have to remove a rear panel and everything is there.... so much easier.
Anyways, I appreciate the help from both of you, the HVAC system sucks as it is, without the recirculate it's nothing.
06-02-2011, 02:20 AM
So I will have to go to a HUMMER dealership?
How much do you think it will run, or is it free being that it is a recall (yea right, i prob won't be that lucky)
Hybrid Mode
