Old 02-15-2012, 09:44 PM
ffl ffl is offline
ffl is on a distinguished road
Default Brake pedal can be pushed nearly completely down to the floor when standing
i recognized that when my H2 is standing and the engine is running, i can push the brake pedal slowly completely down to the floor. it takes a bit more effort that when breaking normally but it's not necessary to push like crazy.
also when doing this, it sounds a bit like when the steering wheel is turned to the end stop.
the brakes work normally all the time, also when driving very slowly or at higher speed.
is this normal?
Old 02-16-2012, 12:58 AM
zdawg8394 zdawg8394 is offline
zdawg8394 is on a distinguished road
Default Re: Brake pedal can be pushed nearly completely down to the floor when standing
mine do the same thing... sounds like air realeasing almost. i really think its fine
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-hummer double brush guard
-vision x rock lights
-5%tint all around
-dual "whips"
-leveling kit
Old 02-16-2012, 05:02 AM
[__--MUD--__]'s Avatar
that isn't right... that noise you are hearing is your powersteering pump getting dragged down or the belt slipping.
if your not aware, your brakes are a hydroboost system which is run off your powersteering pump.
My service manuals are at the shop, but i think w/ the truck off- pump the brakes 4 times hard, hold the pedal down on the last pump and start the truck. I believe it should pump up, or feel the pedal push back on you.
My rigs been torn apart for 8 months under a massive rebuild otherwise I'd go out and confirm that for you.
Old 02-16-2012, 08:38 AM
ffl ffl is offline
thanks for your replies.
i know that it's a hydro boost brake. i also found an article in the internet about hydro boost brakes and they say that it's normal that you hear a certain noise when you push your brake pedal harder that normal.
when i push with normal force, there is no noise.
http://www.scribd.com/doc/6829161/Op...-of-HYDROBOOST
problem is that no matter where you search, when you find posts about this topic, there are always some who say that this is all normal and other ones who say that this should not be...
Old 02-16-2012, 03:46 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
What year is your H2? If it's an 09, I heard there's no more hydroboost... All the 08's and 09's I have been in have that hissing sound. I have not heard it on 07's and under...
http://www.elcovaforums.com/forums/s...ad.php?t=38585
Old 02-16-2012, 04:09 PM
ffl ffl is offline
i have a 2005 h2. in the link i've posted they say that there are normal hissing noises when pushing the brake pedal harder than normal if you have a hydro boost.
did you hear that noise when braking with normal effort?
i only get that nosie when pushing the brake hardly. and i only tested it when the car is not moving.
but honestly i'm not sure how a hydro boost hissing noise exactly sounds like...
