Old 03-15-2012, 04:40 AM
nasty745 nasty745 is offline
nasty745 is on a distinguished road
Default adding light switches to the overhead console
I wanted to add some light switches to my overhead console on my sut, does anybody have pics and ideas on how to do it ? and removing the console to do the mods ? All thought on my projects would help. Thanks Tom
Old 03-15-2012, 02:15 PM
guruerror's Avatar
Default Re: adding light switches to the overhead console
I don't have any pics of the overhead handy, but I currently have mine out to fab in a clinometer...it's a piece of cake to take out; two screws, pull the front down a bit and slide toward the windshield (it's got two hooks toward the rear that hook above the headliner). The A-pillar trim comes off simply by removing the grab handles.
I found some very clean little toggle switches at Radio Shack...
CNTRY
DTOM
Old 03-15-2012, 03:03 PM
SUT-UP SUT-UP is offline
SUT-UP is on a distinguished road
Those are nice guru. Would have saved alot of space there when I mounted my square toggle.
Old 03-15-2012, 03:32 PM
Humvee21 Humvee21 is offline
Humvee21 is on a distinguished road
Is that Line-X'd interior?
Old 03-15-2012, 03:50 PM
guruerror's Avatar
Yes and no....while the majority of my interior - all trim from the front seats back - is Line-Xed, I had to use Duplicolor spray-on bedliner for the dash pieces.
http://www.elcovaforums.com/forums/s...ghlight=line-x
I scored some extra dash components from a guy a while back and had some of them test sprayed with Line-X but it ended up making them too thick to properly fit back together; not to mention that the AC vents wouldn't fit back in the openings. Instead I did the entire dash with the Duplicolor bedliner product and have been very happy with the results...it gave me a consistent, durable finish that matched the texture of the Line-Xed rear pieces.
CNTRY
DTOM
Old 03-28-2012, 06:38 AM
Guru, how's the clinometer coming?
Old 03-28-2012, 02:07 PM
guruerror's Avatar
It came out pretty good...a little fiberglass fabrication, a little bedliner and ta-da:
I still may 'adjust' it to have pics of little H2s instead of the Jeep...or then again, I may just leave well enough alone; it works and it's installed.
CNTRY
DTOM
